Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman riding mower lt 1000 deck jumps out
Arm to adjust cuting hight jumps out of 3 or 4 down to 1 wile cuting pin doesnt seam to fit in slot right unless its in hightest point 6 THANKS FOR YOUR HELP Rick
    President:
  • 1,489 Answers
First I'd try lubricating the relevant moving parts. Spray with WD-40 everywher that makes sense.
If that doesn't help it work better, please, get bck to me.
Posted on May 09, 2009
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to ajust the deak hight on a craftsman lt1000 riding mower
i think that model has a plastic cover just above the foot rest on each side and the adjustment is behind there
Apr 26, 2012 | Craftsman Garden
I bought a new belt for my2005 lt 1000 42" deck
for a deck no.. Most everything on the deck is done by springs.. what i would do is look at the deck make sure nothing is rubbing the belt making it rip apart.. or make it to not engage.. i would with the engine off engage the blade and disengage the blade make sure all the brakes are pulling away from the pulleys and making sure all the arms are moving to tighten the belt.. if nothing is moving then i double check the cable or however engages the deck (all mowers are different) and if need the part. If the cable is not broken and is still on deck make sure all springs are lubed. If you have any questions please dont hesitate to ask
Jul 16, 2011 | Craftsman Replacement Belt for 42" Deck
Will an engine from a LT1000 fit into a LT2000 tractor? Jim
You should have no problem getting the engine from a LT 1000 to fit in place of the original on a LT 2000. The physical space between the two mowers should be identical.
If really helpful, please rate.
Jul 13, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
119 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
