Question about Whirlpool 24 in. DU810CWD Built-in Dishwasher
Plastic fused to hearing element
How do I disengage a plastic dish that has fused to the heating element?
    President:
  • 1,489 Answers
There are many ways to approach this. I assume it has melted and wrapped around the heating element.
One thought is to use a pair of wire-cutters ( called "diagonals"), and cut it off piece by piece.
Another thought is to run the dishwasher with heat option on, let the dish get soft again and pull it off (wear gloves).
Posted on May 09, 2009
OPTIMUS H-4438 ELECTRIC HEATER ALARM LIGHT UP NO HEAT STILL ROTATE
I took it apart found nothing. Put back together took the plastic screw driver with the unit on,gentlly tapped the plastic houding opposite of the heat senser at the top of dish and it works!
Nov 04, 2011 | Optimus H-4436 Electric Heater
MY dryer stoped working
I need your model number to be more helpful. You can start by checking your door switch if the dryer just won't start. You should hear a click from the door switch when you open or close it. If no sound then replace the switch. If the dryer runs, but no heat, often a dryers heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a video to help you check for the problem.
Nov 26, 2010 | Whirlpool Dryers
The dishwasher is not cleaning. It has left a residue all over the dishes especially colored plastic ware glasses. like it doesn't rinse but i have ran the extra rinse cycle and residue is still there. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Plastic dishes have a film. I am using a rinse aid. How do I stop the film on the dishes?
heatman101
Sep 05, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Dishes won't dry. Is heating element the likely problem. Is it replaceable
What temp is your water? You may need to set your water heater up a notch. Try running the dishwasher on the "sani rinse" since this heats to 160 and see if they are drier. Is your heating element working? During the dry cycle with the heat dry on I would open the door and put my hand next to the element to see if it seemed hot. Maybe it isn't working. Also did you put Jet Dry in the dispenser?and also if the setting is adjustable you can dial it up a notch or two. I also like the Jet Dry Turbo. It makes my dishes dry completly, even plastics and this is on the no heat dry.
If there is no heat, then the heating element may be bad. You can get the part, and view diagram at partselect website.
May 18, 2010 | Whirlpool 24 in. DU920PW Built-In...
A small plastic dish has fused to the heating element in the bottom of my Whirlpool dishwasher. How can I best remove it without damaging the element?
I would take a soldering iron and melt as much as you cant away from the element. There may be some residual but it will burn itself off after a few uses
May 09, 2009 | Whirlpool 24 in. DU810CWD Built-in...
Plasric dish has fused to the element
Use strong kitchen shears to cut away as much of the bulk as you can. Without gouging the round element, scrape it with the kitchen shear blade and run a short cycle. When the drying cycle has run for several minutes (you will smell that the element is heating)
open the DW and again use the shears blade edge to scrape the residual plastic from the element. You may need to repeat to get it all removed.
After you have cleaned it up, do some checking during some loads to make sure the heating element is not being turned on continuously during all cycles. You have not provided the the make/model number, so it is hard to get more specific.
May 09, 2009 | Dishwashers
Melted utensil on heating element
Hi amsaunders5,
I'm Harvey the Master Plumber.
Your problem is: Children tried to surprise you by doing dishes. The plastic spatula melted and stuck on the heating coil on the bottom
This is a common problem. First, thank the children, it really wasn't their fault.
It's going to take some effort but you'll have to scrape/remove the plstic from the element. Replaceing the element is not a repair I recomend for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
97 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
