Question about Microsoft Xbox 360 Console
Can you fry your xbox 360
One day my Xbox 360 shut down and two red rings lit up the left quadrant or side. I heard that meant overheated so I put my Xbox in a well ventilated area and left it alone for three days. And when got to plug it back up and play the rings come back. Someone please give me some answers. Also I had my Xbox for a year in a half if that helps.
  • echelon09
    echelon09 May 11, 2010
    how long before it shuts off?
    Problem Solver:
  • 5 Answers
It has been overheated and needs to be reflowed. So if its still under warrenty send it in. If not pony up the cash to send it in and get a new one. You will most likely get a newer version motherboard and they stay pretty cool...
Posted on May 12, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red ring instead of green ring
how many quadrants are there lit if there is three lights then u have the red ring of death (RROD)
if u have 4 i think it means ur AV cable in the xbox isin proberly i think check its connected poperly and if thats not the problem TRY THIS
What we NEED 2 do is OVERHEAT ur xbox to do this u will need something that will fit through the little holes in the back of the console were the fan blows air out we need to stop these stick something like q-tips in the holes then after aba 3 mins it should overheat and two light should indicate (on the left hand side ) it has overheated to turn it off yet wait 1 min let it cook then pull the power out the back and let it cool down 10 mins (dont put in fridge or freezer lol) the turn it on GREEN LIGHTS BACK on line if that didnt work u might need to do x-clamp fix tutorials on utube or if that doesnt work TRY the oven fix were u stick ur motherboard in the oven at 230 uk or 475 usa for 10 mins TOP SHELF on BAKIN TRAY put it FLAT GUD luk
Nov 26, 2010 | Microsoft Xbox 360 Console
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
Xbox360 show 2 rings
2 rings means overheat
leave it in a cold place for some hours and it should be ok
Oct 21, 2009 | Microsoft Xbox 360 Console
Is it possible to fry your xbox 360?
The two red lights is an overheating issue. It correlates with the 3 red lights. First check with Microsoft if your warranty seal is still intact and ask them if its under warranty. also there are some vary qualified technicians who guaranty their work up to 90 days.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Rings of death on xbox360 only upper left quadrant not lit
This is a very common bug with the 360's The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure or overheating. Microsoft offered to repair them even though it sucks sending it in for a couple weeks. I know that there are some temporary solutions like the towel trick but it is very harmfull to the CPU and can ruin it beyound repair. I suggest calling microsoft support and hopefully they will help you out. Hope that helps a little!!
Apr 10, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
2 red lights
suddenly while you are playing you get two quadrants of the ROL (Ring of Light) around the power button of you Xbox 360 console flashing red, this is an indicator that your Xbox 360 console is overheating some how.
That will be due to one of the following reasons:
  1. You set your Xbox 360 console near to any heat source or electrical device.
  2. Your xbox 360 console is not set in a well ventilated area.
  3. There is something blocking the fan openings on your Xbox 360 console.
  4. You are using the Xbox 360 external fan, and basically that's a third party accessory so it sometimes harm the Xbox 360 console.
So, try eliminating all these reasons & if you are still experiencing the same behaviour then you have to contact Xbox 360 customer support to exchange your console or even to get it repaired.
Nov 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
112 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
