Question about Cyberhome DVD Recorder - DVR1600
Remote quit working and can't find a replacement for it!!
My unit works fine but the remote just quit working. I've tried everything and it just won't work.{all the troubleshooting steps} I need the remote so i can use the recorder. {source button} I have tried several universal remotes and none will work. Please help me {my unit is the DVR 1600}
  • 3 more comments
  • westown Oct 16, 2007
    i still have not found a remote and i think i have hit every store and i even started buying the ones that say they r 4 dvd recorders. let me know...............thanks
    joleen
    joleen
    joleen
  • Charles James Nov 20, 2007
    I'm also looking for a replacement remote or the universal remote codes for Cyberhome.
    Any help would be appreciated.
  • sadnky Jan 11, 2008
    Mine was still working...when my granddaughter inadvertanly tossed it in a trashcan without my knowledge...now I need a new one to record. CyberHome is bankrupt, so no help there. Anyone with knowledge of where to find replacements please contact me!
    Thanx!
    Sarah
    Problem Solver:
  • 3 Answers
u can buy a universal remote from ebayer "genuinecopies" for £7.49 + P&P £1.49 or u can purchase a original from ebay "Germany" site.
Posted on Dec 10, 2007
SOURCE:
My Goodman AC is model WMC24-1. Two years ago it quit responding to the remote control. We bought a replacement B1100108. That worked...for awhile.
Make sure the sun is not directly on the unit and nothing is blocking the unit. for once in awhile if the sun hits it just right when you try to use the remote it will not work.that seems to me what is wrong for spring time the sun is real low
Sep 03, 2018 | Heating & Cooling
My remote won't work for my DMP-BD75
If both the remote (which can be tested by a shop for free) AND the front buttons do not work I suspect the unit may have a lock out that disables everything on both except for on off..........
Oct 30, 2012 | Panasonic DMP-BD60K Blu-ray/DVD Player
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
Remote not working
try resetting it by removing the battereis, pressing every button one at a time, then re code for your unit.
Nov 25, 2008 | RCA 3-Device Universal Remote
Remote not working
You can use any digital camera or camcorder in order to check the remote control. Direct the remote (press any button) in direction of camera lens. If remote works you will see the bright spot on your camera screen. If you need more info please advice.
Mar 24, 2007 | Aiwa CSD-TD49 Cassette/CD Boombox
Cyberhome DVD Recorder - DVR1600 Logo
138 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
