Question about Dell Dimension C521 PC Desktop
Solid amber power button and fan running
I have a Dell Dimension 521 that has a solid amber power button and the fan runs. We've checked the power supply by "jumping" it and it seems to work. Can anyone help me solve this problem? Thanks in advance....
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    hello...can you clarify or re-send what is the problem of your unit..i cant understand..Thanks....^_^
    Guru:
  • 830 Answers
First check your memory, it may be loose which can cause the computer to appear in a "hibernation" state. I recommend taking the memory out and putting it back in. The memory sticks are located on the motherboard. Be sure you are grounded before touching anything inside of the computer. Reboot the computer. If this doesn't help, then the problem is the motherboard. Look on eBay for a reasonable new motherboard. You can find them from $39.99 and up. Replacing the motherboard is simple. Just take the old one off and put the new one in making sure to reconnect everything back to normal. If the motherboard is bad, I highly recommend replacing the power source as well because it may have been caused by a surge. These can be found on eBay for approximately $24.00.
If the cause is the motherboard, this would be a good time to consider upgrading your computer. Unfortunately, when you replace the motherboard, you cannot use the OEM of the Windows Operating System that came with the computer because Microsoft considers a new motherboard a new computer. So you will need to purchase a new Operating system as well and I recommend an OEM CD for system builders which can be found on Newegg or Tiger direct.
Posted on May 09, 2009
Dell poweredge 2650 solid amber light
go here and enter the service tag of your server and download dell open manage server administrator managed node. once installed it will tell you exactly what the problem is. i believe the current version of OMSA is 7.1
Dec 10, 2012 | Dell PowerEdge Computers & Internet
Dell dimension c521
it could be and issue with the system board to confirm that try to run a HDD test once using an alternate video source to check id display coes on alt monitor...are u able to enter the BIOS check once.
Feb 12, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
I have a Dell Dimension E520 that I've used for
If the power LED is solid Amber, then the like answer is a bad motherboard or peripheral connected to it. So, remove any expansion cards (I See you already removed the Graphics card) and all external connections (Just use power cord) and see if the system will power on with any different indications. If the power LED stays Solid Amber, replace the motherboard
Aug 07, 2011 | Dell Computers & Internet
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Wont turn on amber light just flash's by power switch on dell dimension 5100.
a solid amber light means that the Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed. HERE is a link to the diagnostic lights, what they mean and possible solutions.
Aug 27, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Motherboard change
jethro..
http://support.dell.com/support/edocs/systems/dimC521/en/SM_EN/tshoot.htm#wp1064555
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Dec 02, 2008 | Dell Dimension C521 PC Desktop
Amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension C521 PC Desktop Logo
251 people viewed this question
Alun Cox
