Question about ATI RADEON X1650 Graphic Card
I installed the ATI x1650 but the monitor is blank when I turn on
Installed ATI x1650 AGP Radeon Graphics card
Plugged in my Dell e770s monitor
Turned computer on to a blank screen
Does this graphics card support this monitor?
  • 230 Answers
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
Cheers
Posted on May 09, 2009
Hello again, i have managed to get the drivers for my radeon x1650 pro 512mb installed and removed the old drivers for my other graphics card, the computer restarted so the installation could take effect...
One of two things I 'see'.
1.Not to insult you, but do you have the monitor plugged into the graphics card? Hey! I've had people do it! They plugged the monitor back into the motherboard VGA port. (If you don't have a DVI connector on your monitor cable, there is an adapter you can buy. VGA to DVI. Make sure you get the Female VGA to Male DVI version)
2.You have a driver conflict. Even after you removed the old drivers, there are still drivers giving you a hassle. The drivers CD for your ATI needs to be installed first. Load the software, shut the computer down, unplug it from the surge protector, THEN install the ATI graphics card.
If you install a graphics card first, before installing the software for it, Windows will recognize that a new device has been installed, and try to match up it's generic drivers.
Then Windows goes 'crazy' trying to decide which drivers it should use.
Jul 22, 2009 | ATI RADEON X1650 Graphic Card
I installed a Radeon X1650 card and having problems
Try the old card & see what happens. If it still does it the monitor is bad. If not make sure to remove the old driver first & then install the new card. Then install the new driver. Should work,if not,then the card may be defective. ATI is kinda common to have a bad one right out of the box.
Jul 14, 2009 | ATI RADEON X1650 Graphic Card
I have Windows 7 RC (patches etc. up to date) with
You could try this link, but with all Beta software nothing is guaranteed until the approved verisons are released.
http://drivers.softpedia.com/get/GRAPHICS-BOARD/ATI/ATI-Catalyst-64-bit-Driver-Beta-for-Windows-7.shtml
Not put down your video card though x1650 is not a "screamer" in todays standards, I'm running a 3870OC myself because it was cheaper than to buy the latest and greatest. I believe you are limited by your motherboard only having AGP? Take a look at this link:
http://www.ewiz.com/detail.php?p=AS-345AG51&c=pw
http://www.buy.com/prod/visiontek-radeon-hd-3650-agp-512mb-ddr2-128-bit-directx-10-1-video-card/q/loc/101/211110588.html
http://www.ewiz.com/detail.php?p=AT-3850AGP&c=pw
You would be able to retain the already installed drivers. It all depends on your budget. On another note try lowering your colors and changing the monitors frequency. I hope this helps.
Jun 24, 2009 | ATI RADEON X1650 Graphic Card
Powercolor x1650 512mb AGP problem
The one you bought is 16x but your MB supports only 8x..................sodeep
Jun 18, 2009 | Power Color 256MB PowerColor ATI RADEON...
I bought a 512MB PowerColor ATI Radeon HD3650 DDR2 AGP video card
hey your monitor is not support the resolution , try lower resolution
Jun 13, 2009 | ATI RADEON X1650 Graphic Card
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
How to enable Crossfire with my two ati radeon x1650 graphic card
You need two pci-e slots. Put the cards in the slots. The cards connect with a crossfire bridge. Then just plug your monitor in and your ready to go. Make sure that you have the software installed and that your chipset supports crossfire. For more info click here.
Nov 17, 2008 | ATI RADEON X1650 Pro, (512 MB) PCI...
ATI x1650 Pro Stops!?
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
Oct 17, 2008 | ATI RADEON X1650 Graphic Card
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 Graphic Card Logo
316 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
