Question about Amana NAV2335A Top Load Washer
Kicks out? My top load Amana had a bad belt. I replaced it with automotive type that was a little bit shorter. Since doing so two things have occured. The belt squeals when it goes into spin. Water is thrown out of the top of the tub, and now after using it to run a few cycles (to catch up), it seems to be kicking out from overheating. After a while it starts back up and runs until it tries to spin. Was the original size belt meant to slip in the spin cycle causing the water pump to remove more water prior to spinning? and would this relieve some of the overload on the motor at the start of the spin cycle?
  • Anonymous Mar 25, 2014
    The spin cycle starts up but quits after several spins. The belt seemed to slip a couple times.
  • 164 Answers
The smaller belt is causing the tub to spin too quickly. the shorter belt is causing the motor to overheat and causing the thermal overload protector to shut dowqn the motor. when the motor cools it starts up again. replace the belt with te correct size and that will solve your problems
Posted on Oct 12, 2007
How to replace drive belt
Nothing could be simpler. No tools needed. Tip the washer on it's back and ease the belt back on there. c5b917f.jpg
Before you mount another belt on there you need to check the pump for stiffness. On these washers the pump sometimes locks up and burns a belt up.
Oct 26, 2010 | Amana NAV2335A Top Load Washer
Amana LW8303L2 will not spine
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
that belt replacement requires some effort but you can do it with a little patience. then you will have your reward plus your washer will be fixed. you'll need a torx head screw driver ( if u don't have one they sell them at the hardware store) and a 1/2 inch socket. it requires removing motor pump assembly from washer and then removing pump from motor. it will take you a while. it's not as hard as it looks. good luck.
Jan 29, 2010 | Amana ALW480DA Top Load Washer
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
Oct 21, 2009 | Amana ALW480DA Top Load Washer
Amana washing machine LW4203W2 MODEL
make sure you have the right belt because there are 2 belts for the machines if your motor mounts to the tub or if it mounts to the bottom of the washer and make sure the belt is on the tensioner
Jan 06, 2008 | Amana ALW480DA Top Load Washer
Change belt.
this is a easy job for a tech but a hard one to regular people have to remove the transmition and thats is by removing a nut in the tub, so better call a tech and pay for it, is not to espensive repair at least in my area...good luck
Aug 07, 2006 | Amana ALW540RA Top Load Washer
Amana NAV2335A Top Load Washer Logo
101 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
