Question about Dryers
How do i fit the belt
I need to put a new drum belt on my hotpoint 9320w dryer but i havnt got a clue how to take it apart
  • 460 Answers
Unable To Locate  Part '9320W'
We were unable to locate a match to the search term you entered, but don't give up!
send me the correct part # n i will be able to help U
thanks
Posted on May 09, 2009
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
I have got a Hotpoint Aquarius tumble dryer. I have just put a new belt on it and a new rear drum axle with new bearings and front bearing pads.I have made sure that the front of the drum is sitting...
Make sure that you have fitted the spacing washer provided with the bearing kit on the drum shaft, and that it is sitting between the rear of the drum and the rear bearing, double check that you have got the front of the drum sitting on all the plastic bearings at the front.
If it still catches, then fit another washer on the drum shaft to space it off from the rear of the cabinet.
Mar 25, 2010 | Hotpoint Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Can't work out how to fit new belt to my tumble dryer it's a hotpoint aqurius dryer duluxe TL22.
You need to remove the rear panel the top console panel,,and then remove the whole cabinet to gain access to the drum and belt.
Then you need to release the front panel at the top to enable you to fit the belt.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
How to remove top on hotpoint 473e dryer , a need to change the drive belt
top should pop off use screw driver to pry apart there are 2 clips on the corner then lid should lift up
Feb 20, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint TDL14 Electric Dryer
Hotpoint vtd00 just replaced the belt for 3rd time put kids clothes into dry and loads of smoke and burning any clues?
Sounds like the motor is turning but the belt is not so, the belt is just setting there burning. You should be able to turn the drum by hand, check the drum rollers and the belt tension roller.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Replacing the belt on my Whirlpool awz7303 tumble dryer
You definitely need circlip pliers to get the fan off though.. It's a bit tricky without them. Othere than that it's a fairly easy job.
Jun 02, 2008 | Dryers
A scratching noise
One, or both drum idler wheels has failed, the noise is the drum shaving rubber of the now stationary wheel.
Belts and Idlers are a standard item that fit many dryers, and your local parts guy has them on the shelf.
Replace both idlers and the belt at the same time, the other wheel and belt will fail soon cause of the extra load, and they are both as old as the first one, and you dont want to pull the dryer apart twice.
Jan 16, 2008 | Hotpoint NLL113EYWO Electric Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
