Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
Water dripping from underside of chest freezer
Water drips from the underside of my chest freezer which is installed in the kitchen. I take it that this is condensation. Is the only solution to run a dehumidifier or can you get drip trays that would fit under the freezer.
I've seen this one before. The problem turned out to be wet insulation. This is likely the problem with yours which probably happened when you last defrosted it.
When the insulation gets wet the problem cascades as more and more moisture accumulates in it. The affected insulation loses it's R-value and the cold transmits right through the wall or floor of the unit.
This problem is impossible to solve unless you cut the case apart and replace the insulation, (but how do you know you’re not going to hit an embedded refrigeration line? Not advisable).
One temporary solution that may last the remaining life of the unit anyway is to prevent air, and the moisture it holds, from contacting the affected area. This can be done the old Red-Green way with some insulation, plastic and duct tape. Scrape any visible frost off first so your new insulation doesn’t become affected as well.
If you tip the freezer up to do this, do it so the largest line coming out of the compressor is facing downward, then let it sit for at least 8 hrs before you start it up again.
Posted on Oct 16, 2007
  • 363 Answers
First make sure the door seals are sealing correctly and not letting the air in to the compartment because this is the only source of water.
Check that there is no ice buid-up around the seals.
Posted on Oct 13, 2007
SOURCE:
My sunbeam chest freezer is pouring water out the bottom,
Probably drains during defrost cycle. It might be missing drip pan at bottom. Check for any missing parts at bottom.
Jun 10, 2014 | Sunbeam 5.5 cu. ft. Chest Freezer, White
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Water is dripping from bottom of chest freezer, also some condensation on side,
dear sir/madam
i think yor freezer.s inside insulation has been damage or warn out so please contcet to your freezer maintenance personnel for replace it .
hope answer the question
thank you
please vote!
Jul 12, 2010 | Whirlpool 10 cu. ft. / 283 liter Chest...
I am defrosting my chest freezer and have the lid open and water is continuing to drip out of the lid. Why?
condensation has frozen inside your lid and now is defrosting and driping out. Reason : there is a air leak in the lid
Jan 09, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water dripping out of the freezer onto kitchen floor i removed back panel in freezer and drip collector under coils overflowing
You will need to unclog this drain with a small flexible drain cleaner, you may be able to use a small piece of a coat hanger, and push the debris through
Oct 29, 2009 | Jenn-Air JCD2389G Side by Side...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
175 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
