Question about Kicker Solo-Baric L5 Car Subwoofer
No sound my L5 15' kicker just stopped playing no scratching or popping just stoppoed playing
  • 63 Answers
Check The Wire Connection And Backtrack It All The Way To The Headset And Power Supply It May Be A Connectivity Problem But If Not You Will Have To See if You Can Have Your Speaker Serviced if Not You Will Without Dout Need To Replace It
Posted on May 10, 2009
    Problem Solver:
  • 18 Answers
First I would check all connections. Then If they are ok, Check the lead wires from the voice coil to the terminals. They can often break. Then if they are ok, Push gently on the cone. Does it move at all(Freely)? If no then the lacquer on the voice coil has swollen from heat and bound the woofer. You would have to either have it replaced(Serviced) or buy a new woofer.If the coil burned out it may have shorted and possibly damaged the amp. To make sure the amp is ok you may wish to check and see if its turns on and that it doesnt go into protection. If its seems ok you can test it with another woofer at LOW volume just to insure there is no amp damage. You dont want to push the other woofer too hard until you are sure the am is ok because it may crank out straight DC voltage and cook the test woofer so be fread to shut it off fast in that case.
Posted on Jul 23, 2009
Wedge a4116 CDs stop
Is this a car or truck problem?
May 22, 2013 | Cars & Trucks
I have two 10inch cvr kickers running off of a 2 channel 800w sony xplod amplifier...everything worked fine for about 3 months until my subwoofers just stopped playing sound..out of curiousty i opened my...
  • Yea, you blew the voice coil. Pressing on the cone where you are is hitting the spot that is making the coil connect again. Just like a shorted wire. Sometimes you can bend it and get a connection. You are gonna have to replace the sub.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 14, 2011 | Kicker Car Audio & Video
In a sealed box ; when i press down on the cone i hear scratching. is this bad? (the speaker still plays) i have been powering it with a kenwood kac-9103D at 2 ohms 900ish watts
I could be getting a problem. If you push down on the very center it shouldn't make any scratching sounds. But if you press down off center you might be rubbing the voice coils along the magnet and thats the scratching you are hearing. When the speaker becomes hard to press down that is when its about to go.
Jan 26, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
SPEAKER BLOWED
IF IT IS COST EFFECTIVE, YOU WILL NEED A RECOIL AS IT SOUND LIKE IT HAS OVERHEATED AND COIL GONE DUFF
Dec 18, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker ZX1000 Open ground issue
you probably have a bad ground to the rca's .
Apr 16, 2009 | Kicker ZX10001 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Xbox 360 Disc stops playing
I have another problem.
My 360 scratches all my discs and makes the perfect circle scratch
Jan 03, 2009 | Microsoft Xbox 360 Console
Disc is unreadable??
Sounds like a defective disc, which are produced sometimes, you might be able to take it back and get a different disc but your probably going to have to shell out another 60$ if you want to keep playing past this.
If you would like to try and fix your disc yourself there are a few ways,
http://www.instructables.com search scratched disc and there are plenty of ways to fix.
http://www.instructables.com/tag/?q=scratched+disc&limit%3Atype%3Aid=on&type%3Aid=on&type%3Auser=on&type%3Acomment=on&type%3Agroup=on&type%3AforumTopic=on&sort=none is a more direct link.
please post what you decide to do.
Nov 17, 2008 | Microsoft Xbox 360 Console
Stopped working.. Blown? or..
how did u wire the speaker ?what is the speaker rated at 2 ohm or 4ohm? thees kicker l7s 15 inch is rated for 1000 rms and 2000 peak the only thing that could of hapend was somthing was touching some were in the wiring or u hade the speaker wired at a load of 1 ohm
May 18, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L5 Car Subwoofer Logo
279 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
