Question about Mitsubishi WS-55857 55" Rear Projection Television
Xbox 360 on rear projection tv
I have a Phillips HD rear projection tv. I've hookedup my xbox 360 and when i turn it on the picture is split vertically down the middle of the screen and has the same image on both sides. if i select to play a game it all worked but the picture is really narrow and on both sides of the screen. what should i do, please help
premtech
  • 934 Answers
SOURCE: Mitsubishi WS-65809 65 in Projection TV problem with vertical stripes
I'm fairly sure that the 2hdw board is the culprit here. The 2hdw pwb is Mitsubishi original p/n# 935c966001 which has since been substituted to p/n#935c966002 and costs roughly $420.00 dollars plus shipping.
It's a common failure in these units, but it's not a difficult repair for a reputable shop..
Another alternative is to have ashop pull that board and send it in to PTS Electronics for rebuild. That might save about $100.00 dollars.
Please don't rate me badly for the bad news.
Good Luck!
Bill
Posted on Nov 25, 2007
SOURCE: Mitsubishi Projection TV problem
I just started seeing red lines going across screen and picture has ghost now. Is lamp going bad? Red line is a somewhat u-shape about 1/4 from top of screen.
Posted on Mar 15, 2008
SOURCE: My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
Posted on Oct 22, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Posted on Dec 08, 2008
  • 121 Answers
SOURCE: Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Posted on Feb 25, 2009
My 52 in rca tv wont come on..the power button lights up and then shut off and then lights up again and shuts off..a couple of times when it did come on..the picture was wiggly..and when i play my...
Sounds like you have A blowed fuse on SSB board its the one you hookedup your xbox into fuses on right and left side of bottom tuner they small brown looking caps but are fuses. for replacement boards call UED for prices on new and rebuilt board 1-800-648-6657
Sep 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 1080i xbox 360 hook up
you need to change the settings on the xbox aswell.
go to your settings menu and change the picture settings to 1080i
Oct 27, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Rear input connectors
Does it give you a "No Signal" on the screen, you may have to check the xbox and make sure you have it setup to output a HD signal. Let me knwo what you find.
Oct 26, 2008 | RCA Scenium D40W20 40" Rear Projection...
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi WS-55857 55" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
