Question about Kenmore HE2 Plus Front Load Washer
Cannot get front panel off to fix leak
My washer has a leak.  Using a flashlight and a mirror I can see where the leak is.  The problem is that I cannot get the front panel off to get access to the broken part.  I got the bottom service panel off, but the tube that is broken is near the top, under the soap tray.  It looks like I need to take the door off first, but the screws are SUPER tight.  They'll be stripped before they budge.  Is there another way?
PS.  the washer is a front loading kenmore that looks similar to the pictured one for this group, but I don't know that it is exactly the same model.
Thanks for any help.
What you need to do is to have the following tools. torx and small wrench. used the torx screw for the screw next the tray soap on top and used the small wrench to open the four bolts two on top and two on the bottom. take the front panel off and then check for cloth inside the tube front the top where the water is coming and follow alway to where the hose connect to the machine that is usualy where the leaks is coming maybe your hose has a hole or somthing stuck inside that hose and that makes the water leak. It happen to my and I fix it.... it work well now....
Posted on May 21, 2009
Jason, you dont need to take the whole thing apart to get at that, in a nutshell take the top cover off and take the nuts out that hold the detergent/fabric softener dispenser in, it has nuts on the front and on the top, once you get the dispenser out its a lot easier to work on that coiled rubber tube, you can at least get your hands in there to take it off, i hope you dont find the same problem i did, the plastic around the rubber hose was cracked meaning the tup itself is cracked. i filled the cracks in the plastic with jb weld and wait a while. ive had nothing but issues with this washer , very poorly constructed.
Posted on May 17, 2009
The underwire in my bra is stuck inside washer somewhere
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Aug 20, 2012 | Frigidaire Affinity ATF6000F Front Load...
I have a radiator leak on the bottom of the radiator of my 2000 Chevrolet z71 1500. I don't know where it is coming from exactly. It is a so drip and I can see green coolant on the ground.
Coolant leaks can sometimes be difficult to locate the exact origin of the leak. That is why proffessional technicians use pressure testers, bright flashlights, inspection mirrors, and in some cases even borescopes to locate the cause.
With that said, I would say that if you have a "radiator leak" and it is "on the bottom of [your] radiator" my first guess is that it is coming from the radiator itself....check the area of the radiator where the plastic tanks are crimped to the cooling tubes (main radiator core). Sometimes the fittings in the tanks leak where the transmission cooler lines connect.
I have also seen leaking radiator caps misdiagnosed for a leaking radiator....Sometimes they will leak and the antifreeze will run along the sides of the radiator and "mimick" a radiator tank leak. Remember, the coolant almost always travels DOWN and REARWARD. Sometimes it goes way to the left or the right, but it still goes down and back from there.
A bright flashlight and an inspection mirror will verify most leaks. You may also want to detach the fan shroud and move it back for better inspection of the radiator. - start where you can see the coolant and follow the trail upward....
May 13, 2012 | 1999 Chevrolet K1500
Water is leaking from somewhere in the machine...any suggestions...?
The cause could be anything, drum, hose, pump, etc. If you have a phillips or + screwdriver, there are two screws on the lower front panel near the bottom of the machine. Unscrew them and the front lower panel can be removed by pulling the panel from the machine. Once the panel is removed, you can use a flashlight to see where the water is leaking. Hope this helps you.
Dec 15, 2010 | GE WSXH208A Front Load Washer
How often do I need to service a BMW 123d?
Hi and welcome to FixYa. I am Kelly.
Here are your service intervals:
NOTE Besides Oil changes there are inspection intervals I & II
http://www.savagebmw.com/Service/content_service_Intervals.htm
Inspection interval I
BMW Inspection I (return to top) Undercarriage
  • Change engine oil and filter while engine is at normal operation temperature.
  • Check transmission for leaks.
  • Check rear axle for leaks.
  • Visually check fuel tank, lines, and connections for leaks.
  • Check condition, position, and mounting of exhaust system. Examine for leaks.
  • Check power steering system for leaks.
  • Check overall thickness of front and rear disc brake pads.
  • Examine brake disc surfaces.
  • Clean brake pad contact points in calipers.
  • Grease wheel center hubs.
  • Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  • Check front control arm bushing for wear.
  • Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  • Check all tire pressures (including spare). Correct if necessary.
  • Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks.
  • Check coolant level and antifreeze protection level; add coolant if necessary.
  • Check level of brake and clutch fluid in reservoir; add fluid if required.
  • Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  • Check air conditioner for operation.
  • Reset Service Indicator.
Body/Electrical Equipment
  • Check battery electrolyte level and add distilled water if required.
  • Perform batter load test.
  • Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  • Check instrument panel and dashboard illumination.
  • Check all warning/indicator lights, check control.
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  • Check wiper and washer system(s); wiper blades, washer jet positions.
  • Check condition and function of safety belts.
  • Oil hood, trunk/tailgate, and door hinges.
  • Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Check central locking/double lock.
  • Replace microfilter or Acc. Cabin Filter.
  • Check heater/air conditioner blower, rear window defogger.
  • Check rear view mirrors
  • Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  • Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection interval II
BMW Inspection II (return to top) Undercarriage
  • Check thickness of parking brake linings.
  • Half-shafts; check for leaks at flexible boots.
  • Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  • Replace spark plugs (as applicable by year and model)
  • Replace intake air cleaner element.
  • Replace microfilter or Acc Cabin Filter.
Final Inspection
Service indicator lights if installed:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
That should just about cover the works other than failures.
Thanks for using FixYa!
Kelly
Feb 16, 2010 | 2008 BMW 1 Series
Water is leaking from the front of my topload washer it is a whirpool
do a quick visual test , remove front panel , run washer as usual , with a FLASHLIGHT look or leaks, if its coming from the bottom center of tub , then needs to replace the center seal , hope it helps , AJ
Nov 14, 2009 | Computers & Internet
Have a LG Tromm wm2688hnm and is leaking water? Does anyone know what causes this and how do you fix it?
If leaking from the bottom it could be a number of things and you would have to remove the back panel to start. Then do the rinse and spin and using a flashlight try to locate the leak. Have towels handy. For us, in our 5 yr old LG - the bellow (the black large tube connected to underneath the tub) had holes in it. A $10.00 part online.
Jul 04, 2009 | LG WM1814CW Front Load Washer
When it rains water in in the rear sloshing
The 1997 Sebring convertible has rocker panels (the metal that goes from front to back wheel well and directly under the doors) that have five drain channels each.  The sloshing noise occurs when the drain holes plug up and a rocker panel fills up with water.  Often, the water will then leak into the right rear footwell, soaking the carpet.  A quick fix is to locate the drain holes and run a flat (unused) twistem-tie (they come with your trash bags) through each hole several times.  Commonly, doing so will result in a deluge of water, along with spider web parts, leaf parts, and whatever else washed into the rocker panel fromo the rear window.
To find the drain holes, just 1) lie under the car with a flashlight, or 2) sit alongside the car with one of those mirrors that come on a telescoping stick.  Since I don't like to lie in dirty water, I use the mirror to guide my twistem-tie (or ice pick or spring wire or whatever) into each hole.  NOTE:  the drain holes are flat and run at a 30 degree angle from back to front on the right side and from front to back on the left side.
May 17, 2009 | 1997 Chrysler Sebring
Wbsr3140 washer leaks
looking at the washer the front panel is held on by clips, take a flashlight and a butter knife and slide the knife in the top crack of the front panel and slide to one side until it stops. this is a clip. usually in line with the washer lid seam. there is one on each side. push in and up on the clip while gently prying door forward, and wala it will open. if you can fill the washer with water alone and it doesnt leak. you probably have a soap issue which can be solved by cutting the soap usage down
May 17, 2009 | GE WBSR3140DW Top Load Washer
My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
May 31, 2007 | Whirlpool LSQ8000 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
197 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
