Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Echo chain saw 16 inch will not start
Good spark to the plug and getting gas but will not hit a lick
    Scholar:
  • 173 Answers
You need to play about with the timing adjustment.
You can adjust the timing by two different methods.
The first is to adjust the space on the spark plug.
The other is to adjust the gap between the contact, and the coil/magneto.
There ya go, FixedYa !))
Don't forget to rate, thanks.
Posted on Aug 01, 2009
Crank mechanisum becomes too jamed to pullt hrough. pulled handle off crank cord while attempting to start.
Posted on Oct 26, 2009
How to remove a fly wheel
Intermittent spark, new spark plug, no start
...chain saw cs 38cc smh038ub24ra em. u.s. epa ph-1, 95-98 ca. emissions regulations for ulge's. d048 Remove your flywheel cover then unhook the small wire from the magnito (coil). Tuck this wire out of ...
Oct 07, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do I change spark plug in my chainsaw
find where spark plug wire is connected to plug and disconnect very gently, remove spark plug with proper 13/16 or 5/8 wrench or socket and replace with new spark plug
Sep 16, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
Saw will not fire. has spark at plug and compression is 130 will not fire even with starter fluid
If there is fuel to the plug, and a good spark it should fire, all i can think of is the ignition timing is out due to a sheared flywheel key.
Jun 11, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch MS1636NAV chain saw. The engine starts with the choke pulled out. When I push the choke in the saw dies. I've changed the spark plug, replaced the air filter. changed the gas, 40:1.
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Oct 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
When you start the saw it runs for a sec then u hit the gas bogs then clunks out
Start with cleaning your air filter really well
Check your spark plug for a good solid spark that goes to the electrode and not to the side of the plug - if it fires to the side replace the plug
Has anyone fooled with the carb hi/low/idle settings?
Apr 01, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
check that plug is getting spark (remove plug, w/ cap attached hold tip of plug on cooling fin. pull starter rope, should see spark). if not receiving gas check filter in tank, if ok procede to carb possibly add a bit of starter fluid.
Mar 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
633 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
