Question about Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack
Charging ijust brought the walkies talkies on thursday from the pawn shop and i charger it when i got home put the red light keep showing? when the red light is on does that mean it's charger or what? Because my husband went brought some rechargerable battiers on yesterdy but it didn't do nothing. What can we do?
  • 181 Answers
Put batterys in a normal charger. if still nothing,. problem lies with radios.
Posted on May 13, 2009
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Light stays red after being plugged in for 24 hours
I am assuming that you are speaking of the charger. The Red LED shows that the charger is plugged into the wall. It does not show the charge status of the radio. These are very simple units, and it is not a "smart" charger.
Jul 29, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
Ok i baought 2 Motorola MJ270R walkie talkies, Then i found 1 more with no charger or anything at my moms house, And there all the exact same walkie talkies there all MJ270R Walkie talkies, And was w
Hello Ty,
Tis a problem you have there, however I would advise you take one of your radios to radioshack or similar store, and the folk there should be able to assist in finding the apropriate chargers for you.
I hope this helps you in your quest.
Cheers,
Peter
Mar 08, 2013 | Motorola Walkie Talkie 2-Way Radio
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
The battery is flashing red when charging
You do not mention which model of Motorola radio you are charging, so this will be basic information: Typically if a charger blinks red when the battery is initially put on the charger, you either have:
1) Dirt contacts. Solution: Clean with pencil eraser, both radio and charger contacts.
2) Shorted or bad battery. Solution: Replace the battery.
3) A bad charger. Replace charger.
Some simple troubleshooting might determine your problem. Try the battery on a different charger and see if you get the same blinking light. If so, you have a battery issue. If the problem disappears when you place it on the known good charger, then you know you have a charger issue.
Best regards.
May 17, 2011 | Motorola Walkie Talkie 2-Way Radio
I have a gmr885 walkie talkie set...we used them last weekend as we moved from ct to maine..they were charged well before we left ct and when we got to maine put them in the charger, no lights showed lite...
You might try cleaning the battery contacts and the charger contacts with a pencil eraser. It could be you are not getting good connection. Also check your batteries to see they are installed correctly and are touching the internal battery contacts to the radio. Try switching the battery pack to the opposite radio, as a test to see if one will turn on. It would be highly unusual for both radios and/or chargers to fail at the same time. So the problem is probably something simple.
Jul 24, 2009 | Radio Communications
Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Sep 21, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Radio Communications Logo
438 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
