Question about Baumatic B200LS Stainless Steel Electric Single Oven
Displays FBEO hi the electronic programmer/temperature display on my Baumatic single oven model no.B200LS-A keeps displaying FBEO whats the problem please help
barkencoa
  • 3463 Answers
SOURCE: Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Posted on Jan 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
jyackle5
  • 8197 Answers
SOURCE: Hi,
Try this site
http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B180SS-B
Good Luck and Please Rate FixYa!
Posted on Mar 08, 2009
  • 44 Answers
SOURCE: ''stop'' message on electronic programmer - Whirlpool oven
Hi
all you need to do is set clock as oven is in auto mode
to do this you need to press the middle button a couple of times
hope this helps
Posted on Mar 19, 2009
localwonder
  • 6784 Answers
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Posted on May 22, 2009
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
My Baumatic oven now displays F4E0 after a power surge, the fan still works but there is no heat.
more than likely the heating element blow but check to see if theres a fuse in line with that element
Jan 23, 2010 | Baumatic B187 Electric Single Oven
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
My Frigidaire electronic single wall oven FEB275ASB won't stop beeping. It displays a P4 error
F4 Shorted oven sensor (RTD) Check for shorted wiring between EOC and RTD. Check resistance of RTD using resistance table. If resistance test is correct and wiring is good replace EOC TEMPERATURE °F RESISTANCE ω 32 ± 1.9 1000 ± 4.0 75 ± 2.5 1091 ± 5.3 250 ± 4.4 1453 ± 8.9 350 ± 5.4 1654 ± 10.8 450 ± 6.9 1852 ± 13.5 550 ± 8.2 2047 ± 15.8 650 ± 13.6 2237 ± 18.5 900 ± 13.6 2697 ± 24.4
Sep 20, 2009 | Frigidaire FEB27S5A Electric Single Oven
E3 F1 code on key pad kenmore specail edition
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F3 message displayed
HI, you oven temp sensor if malfunctioning. the circuit is open. its basically dead. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 22, 2009 | Frigidaire 24" Built-in Single Electric...
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
DCS Single Wall Oven Model WO-130-SS
Order part #211708 from 1-888-281-5698 DCS Fisher@Paykel new Zealand. Only need philips head screw driver and twenty minutes. This part is a upgrade for lcd only. old part was a three part system, but no need for three parts only lcd screen.
Jul 07, 2008 | DCS WO-130 Stainless Steel Electric Single...
What do I do now that the temperature markers have been scrubbed off??
Go to www.baumatic.co.uk then go to their online catalogue. Find your oven model & download the user manual. You will find 2 very clear pictures of the facia. Regards
Jul 16, 2007 | Baumatic B180 Electric Single Oven
Baumatic B200LS Stainless Steel Electric Single Oven Logo
763 people viewed this question
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
