Question about Meade DS-2114 ATS (325 x 114mm) Telescope
Meade DS-2114 ATS LNT
The telescope is supposed to automatically align with magnetic North and then to 2 alignment stars.  I called Meade and they told me to calibrate the motors--which I did.---The telescope will automatically calculate level and then goes to Calculate North Mode---but all it does is slew continuously around in a circle.--I let it slew for several minutes before I turned it off. I have retried this several times.
 How do I get the telescope to align North
Thanks Mark
  • 1 more comment
  • Anonymous Nov 28, 2007
    I had that happen to me on my DS2080. I had the LNT/Smartfinder module installed backwards. I unscrewed it and turned it around, and it worked fine.
  • Mark I Feb 25, 2008
    Thanks Guys---I kept going back to Meade for assistance and they finally sent me a brand new telescope.---This is after replacing the smartfinder module and onboard computer.---The new one aligns fine.
  • tank13 Jan 01, 2009
    My scope always goes NW no matter what I do and everthing is off after that. tried everything. Custumer service just says cal. moters and sensors but that doesnt help.
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Posted on Dec 18, 2007
I also face the same issue. Suprizingly, there is a place close to my window where it would not align to the north and keeps rotating in circle. But if I move the telescope to the center of the room or someother place in the house, it acurately finds North in one go. I think, there is some magnetic field disturbance in the place close to me window, So if you telescope is continously rotated while tryin to find north, move it to another location and try again.
Posted on Feb 25, 2008
Display shows when you turn on switch that system detects motor failure
Put new batteries in it--- and do a RESET on the hand controller. Then do a Calibrate Motors--- and then re-train the drives.
You will also need to enter Time, Date, and Daylight Savings Time = NO right now.
After this take it outside and level the tripod, and do a two star alignment.
Jan 03, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
Hi i have a meade ds-2114ats-lnt.. when viewing it appears upside down.. can u help?
All astronomical telescopes show upside down images, it's completely normal. Read my FAQ tip on my profile page.
Sep 21, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Calc north not working
Are you running this scope off of the internal batteries? If you are put in fresh batteries. The hand controller will go wacko once the batteries fall below about 60% charge. We always recommend that goto scopes be run from a separate 12 volt power pack. If new batteries to not solve the problem, return the scope to the dealer while it is still under warranty.
Apr 06, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
How do i use my meade DS2114 ATS-TC
Here is the manual:
Read it TWICE! Then Calibrate Motors using the same power source you will use outside at night.
Then Train the drives, then enter time, date, daylight savings time =NO right now.
Do a two star automatic alignment.
Jan 03, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Is it possible to set up the meade telescope ds-2114ats-lnt to have it set up outdoors and view indoors. Set up remotely in other words. I have the cables and software to navigate indoors but still have to...
It may be possible but expensive. You have to be able to control the scope remotely, AND transmit the image in the eyepiece inside.
Both are possible, however expensive, more than you paid for the entire telescope!
Aug 26, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
Auto Align??? DS-2114ATS-TC
The alignment stars will be nearby BUT MAY NOT BE in the eyepiece-- you must center the alignment stars using the hand controller-- after you center the second star the GOTOs should be OK.
Dec 28, 2008 | Meade DS-2114 ATS (325 x 114mm) Telescope
I'm having problems allining my telescope keep saying below horzi
Did you read the manual completely-- most of the DS telescope series require that you-- eneter Time, Date, and Site, set Daylight Savings Time, and TRAIN the scope.
Then you select Automatic alignment and center the two alignment stars-- these scopes usually have a HOME position which you should read about.
Dec 26, 2008 | Meade DS-2114 ATS (325 x 114mm) Telescope
Cant see a thing!!!!
use the laser pointer that you put on the telescope when you were putting it together. or take the whole front cover off and look at the reflector and see if you see anything if you do try it again and see if this info helps please respond thanks and your welcome
Sep 01, 2008 | Meade DS-2114 ATS (325 x 114mm) Telescope
You must CENTER the alignment stars -- usually they are near -- but may not be inside the eyepiece.
Centering the two stars makes the GOTOs accurate.
Make sure time, date, site, is correct--- and if your scope has a "training" routine in the manual--- be sure to do it.
May 23, 2007 | Meade TeleStar DS-2114ATSA Telescope
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
542 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
