Arghhhh!!! Problems with my Lacie Brick crashing my Mac
Hi there...hopefully you can offer me some suggestions on what to do about this. Okay, so here's the deal. I've had my Lacie 250GB external (the red lego one) for about 2 years now...I have had no problems with it up until now. I work on a PowerMac G5 and store my client files on my Lacie so they're not sitting on the Mac. Problem is, about 4 days ago, every time I power up my mac when it's connected to the Lacie (even if the power is off on the Lacie), inevitably in between 5-20 mins, the mac will crash...saying "your computer needs to be restarted". I have found that the only way I can keep the mac stable is to disconnect the Lacie altogether so that it won't crash on me. Problem is...my client files are on the Lacie and I normally keep it powered up all day so that I can move files back and forth while I'm working. Any suggestions as to what I can do? Have you ever heard of this happening? I don't think it's a problem with the computer itself, because it seems to run normal when it's not connected to the Lacie. I've had macs now for almost 10 years and have never crashed one more than this G5 because of this problem. Help please!!!!
  • 4,889 Answers
O you use this software called
MacDrive - 7.0.10If yes dump it immediately...This problem was occuring on my friend's PC too..due to that useless software!
Posted on Oct 11, 2007
  • eagle338
    eagle338 Oct 11, 2007
    I have also heard that almost all the versions of this software are mere crap!
  • eagle338
    eagle338 Oct 12, 2007
    There's nothing wrong with your comp or your Lacie.The software is the culprit!
SOURCE:
Thumbnail image is 'pixellated' on LaCie hard drive
what system.
a hard drive has no graphics.
its just a brick of spinning memory media.
tell the helper what system you have exactly with model name and numbers.
LACEI what.?
what id you plug it into. MAC, PC? Linux ,what? be specific.
please. (and better answers arrive for free)
Oct 01, 2013 | LaCie Computers & Internet
I connect my Lacie d2 quadra to my mac with firewire 800 and it works fine, but when I connect the same hard disk with esata, it appears on the desktop screen, but the blue light won´t stop...
Hello.
I have had simular problems with one of these. It can be due to the drive not starting up or shutting down properly or a powers issue.
I woud recomend dissconecting all leads from the back of the hard drive.
Now plug in just the mains power. Now turn the drive on and let it boot up until the light stops flashing. Let it stay constant for a while, now press the power/led button to let it shut down properly on it's own.
Now turn of your mac. with the hard drive still OFF, connect the fire wire to you're mac and HD. Now power up the Mac. If the HD does not power up on it's own, turn it on now.
Hopefully all should be ok now.
If not, try to test it on a PC. It may sound strange, but it can make a difference. Now do all the above again.
Any Luck?
Ok another thing is to try a psu. Hopefully you know someone with a drive you can ask to test their power supply with.. Try all of the above things again? Any joy? if it all workd ok with their power supply and not your's, your mains transformer is bust. It's caused by a capcitor that blows (quite common). If your drive is recent, you may be able to harrass Lacie for a new one, if not I managed to get a Lacie psu from ebay for around £25.00+p&p on ebay.
A final thing to check is what firewire version your mac is against the firwire version of the lacie. Sometimes this can give issues.
Hope this helps.
Jan 13, 2011 | Computers & Internet
Lacie icon not showing up on my desktop
Try disconnecting the usb cable from the drive and take the drive to a quiet place.
Power up the drive and put your ear next to it. Listen for the internal disk to speed up and then click (which means it's ready). At this point you should have a solid blue LED on the enclosure.
If not, either the disk is bad, the enclosure's controller is bad, or the external power brick is bad (put your ear next to the power brick and if you hear a faint clicking sound, the power brick is bad and you can order a new one from LaCie for about $16.00.
You rate will be much appreciated!
May 07, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
When I put my mac in sleep mode and restart it I get a message that says I have not put my lacie hard drive away right. How do you do that.
The message you are getting is refering to removing the Lacie before disconnecting it.
Just as you eject a drive before unplugging the cables to prevent corruption you must do the same before going to sleep as turning off the power to your USB ports(which happens in sleep mode) is no different than unplugging the drive without ejecting the drive when the computer is running.
If your Mac is set to go to sleep and save power when it is not in use then you should only plug your Lacie in when you are using it and should eject the Lacie before going to Sleep.
Failure to do so will eventually result in a loss of data.
If you have already lost data from a Mac formatted Lacie drive then you should refer to the below link for assistance in recovering your files, if not simply follow the above steps and you should not have any problems as a result of your Mac going to Sleep.
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Feb 11, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Power Adaptor for 500GB LaCie P3 HD USB 2.0 7200RPM 8MB USA?
Both power adaptors are 4 pin, ITHINK that the Porsche that you have is the same as mine which has the smaller (4 pin DIN) plug 34W power supply.
But check on LaCie's site: http://www.lacie.com/asia/products/product.htm?pid=10857
Hope this helps.
Chris
Jul 23, 2008 | LaCie Computers & Internet
Lacie brick 60G hard-drive "read only" problems
Try formatting it first. If it is not possible to format this way, try to format the drive from the command prompt
Start - Run - type 'cmd' . once inside the command prompt, type the command format drive: where drive is the drive letter
May 13, 2008 | LaCie Brick Mobile (301054) 60 GB Hard...
I dropped it on a floor. Now it gives an alarm sound.
wow..you'll need to get a data recovery expert to 'snapshot' your drive to attempt to recover your data. I'd suggest that the 'drop' did a major mechanical deal, like a head impact crash. Not good. A local tech store/computer shop MIGHT have the tools to extract the data. Last time I checked, it runs from 100 to 300 bucks, depending on what kind of files are retrieved.
Feb 16, 2008 | LaCie BRICK (301063U) 300 GB Hard Drive
Hard drive not mounting on mac
Is the drive formatted NTFS? That will never mount on a mac, but can be seen in the Disk Utility.
Dec 19, 2006 | LaCie BRICK (301063U) 300 GB Hard Drive
Brick connection is not registering
It sounds like that brick fell. All bets are off when a hard drive falls or receives shock. Put your ear to it and see if it is making any strange sounds.
Keep me posted.
Nov 21, 2006 | LaCie BRICK (301063U) 300 GB Hard Drive
Open Questions:
AOL MAil HeLpliNe /.*+.{1-/855/*536/*5666/}#[email protected] /.*+. NuMbER IOWA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 21, 2019 | AOL Computers & Internet
AOL MAil CuStOMeR -.+{1^/855~/536~/5666-}/.*+.SuPPoRt PHoNe NuMbER HELPLINE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Computers & Internet Logo
202 people viewed this question
Ekse
Marvin
Marvin
