Question about Kwikset Locks & Locksmithing
Kwikset door knob lock on front door that unlocks by itself.
I have a Kwikset door knob lock on my front door. It is about 30 years old. If you turn the knob back and forth several times, it unlocks. Is this repairable, or is it just worn out? Thanks.
JWM707@AOL.COM
  • 38 Answers
SOURCE: kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Posted on Sep 11, 2008
  • 148 Answers
SOURCE: changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Posted on Jan 06, 2009
SOURCE: need to know how to key my own lock
Try www.bargainlocks.com for keyed-alike door locks and deadbolts as well as other supplies you might need, check them out, they are great to work with, ship things out ASAP and get them to me on time, and have free shipping if you need alot of locks, I've used them a couple times and have never been let down.
Posted on May 11, 2009
rsmith972278
  • 160 Answers
SOURCE: the key for my kwikset door handle lock won't
The answers to your problem are very numerous.
Usually what has happened is that when the lock was installed the pins (the part of the lock that rides on the cut part of the key) were not facing down. This allows dirt and debris to collect in the pin holes and also if a spring breaks it won't push the pin up to the cut part of the key. Some locks you can't even rotate to a position that faces down.
What I suggest is removing the knob or lever lock from the door and blowing out the key hole with compressed air. Work the key back and forth through the lock and blow it out again. If this doesn't work ... try and get a refund or a replacement from wherever you got it. Remember your time is worth money and so is your frustration. Don't waste allot of time trying to fix something that can be replaced relatively cheaply.
Thanks,
RSMITH972278
Posted on Oct 13, 2009
agent91
  • 2100 Answers
SOURCE: How to install kwikset door knob with lock
Are the holes in the door? Are you replacing the old lock? Need to know these things, or I will be typing a bunch of stuff you don't need. Most doors come pre-bored. If not, you need 2 bits, One is 2 1/8 inch cup bit, the forstner type is a lot more expensive, and a 1 inch paddle bit, again, the forstner bit is expensive. Measure up the door app 39 inches, unless there is a lock rail on/in the door, then measure to the center of that. Then on the inside of the door, measure back 2 3/8, most locksets now are adj for 2 3/8 or 2 3/4, you can use either one. You can drill either hole first, To drill your one inch hole in the edge of the door sighting along both sides of the door with your eyes crossed so you can make sure you are going straight, you don't want to bust through the side of the door. Then get the big bit out and drill from the mark till you just come through the other side, then back it out and drill from the other side so you don't tear out the hole. Your 1 inch hole should be all the way into the big hole.Then get you chisels, the sharp ones, put the plunger in the one inch hole, nice and straight, then mark the outside with a sharp pencil, cut the line with the chisel then cut out the waste about 1/8 to 3/16 deep, make sure it fits nice and tight, Predrill the two screw holes, or you will split the door.Get the lockset out, the key to the outside, and the button on the inside of what you are locking. Line up the holes, you might have to spin the button to get them to line up, then put in the 2 long screws. Mark the jamb with the striker, To get it right, put the striker on the door, hooked into the latch, mark the edge of the door with a pencil,then put the striker on the jamb, backwards, to the line you just marked, then out line it, use your 1 inch bit to hog out the middle nice and neat, cut the rest out the same way with the chisels, predrill the holes, you should be all set. OH the deadbolt? You didn't mention that, it goes the same way as the lockset, only the hole is smaller, 1 1/2, I think, you will have to check that. Now you know why people call carpenters.
Posted on Feb 17, 2010
Kwikset lockset does not lock
The shaft for the lock fits in the knob. The lock on the knob might be 90 or 180 degrees out of rotation. Please remove the know and twist the lock 1/4 turn and put it back together. Also you may need to reset the location with a key and when the lock knob is off, turn the lock set with the key, then turn it and replace the knob.
Mar 01, 2018 | Kwikset Locks & Locksmithing
Quickset door locking knob cannot be locked from inside without jijjling the knob
a shot of WD-40 in the key hole. also spray the key with WD-40 just before inserting
Nov 22, 2012 | Kwikset Locks & Locksmithing
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
My exterior door lock (Kwikset) is stuck shut. The knob will not turn. I removed the knobs and tried to pull the mechanism back - but unable to. The door is therefore stuck shut.
Get a big scredriver and put it in the square in the middle of the mechanism and turn it till it opens, or you will just have to pry it out with the scredriver.
Apr 05, 2011 | Kwikset Locks & Locksmithing
Replaced my transitor battery on my front door. push enter from outside the door enter turns green ......turn deadbolt and it locks. Tried to open door, push the lit numbers of " 4 digit code" enter key is...
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Oct 21, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
Professional Door Lock installation Kit: After 2-3 years all of the sudden none of our keys...
The lock is bad very common problem with them, If you got 2-3 years out of your "smartkey" lock those things are like dinosaurs most of them don't make it 3 months and this problem happens. Get the traditional pin tumbler version of the Kwikset lock and this will never happen again. Plus it will be an easy swop out since they use the same latch.
May 18, 2010 | Kwikset Professional Door Lock...
Change batteries on kwikset pushbotton lock.
If it's the lock I think it is, all you need to do is to remove the two screws on the inside of the door that holds the lock to the door. Pull straight out on the whole assembly. You should see the exposed battery once you have removed the outer case and handle.
Hope This Helps,
RSMITH972278
Nov 10, 2009 | Kwikset Professional Door Lock...
Door knob will not stay set. Keeps slipping out.
i would say the only fix for it is a replacement.sounds like its wore out, sorry
Jul 11, 2009 | Kwikset Sheridan Handle Set
Changing doors would like to know how to take off kwikset door
good luck
Dec 29, 2008 | Kwikset Professional Door Lock...
Won't unlock door and beeps when code is entered
Got in contact with kwikset took out battery pack then put it back in. keypad reset itself.
Dec 28, 2008 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Locks & Locksmithing Logo
304 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
