Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
No lights on except power light.
Hello i have recently bought a recetified netgear WNDR3300. As i plugged it in, it was working fine although it was dropping signal reception so i upgraded the firmware to DD-WRT.At first for a few minutes it worked fined, but afterwards the wired connection did not work and after a few minutes the wireless connection also dropped/stopped. Then i started to reset the router to the factory default setting and so tried the 30/30/30 way. but after the first try the WAN led light turned off after the second try the wireless signals(both 2.4Ghz and 5Ghz) stopped blinking. now only the power light is solid.any help would be appreciated. thank you.
  • hitesh_r_red May 10, 2009
    Thanks for the help. I loaded Netgear's Firmware using TFTP and the router is working fine.
    Genius:
  • 1,268 Answers
The firmware has been messed up. DDWRT might be incompatible with your router. I would highly recommend to reload the factory firmware or the latest firmware from Netgear's website. Loading 3rd party firmware will void the warranty of your device.
Posted on May 09, 2009
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
No power light lan and wireless blink once
try a hard rest... then its dying I'm afraid. reset what ever it plugged into also
Jul 05, 2012 | NetGear WNDR3300 - RangeMax Dual Band...
I purchased a netgear wndr3300 wireless router from private owner and it did nt come with setup cd.how do i set it up with out cd?
First off reset the router using the Small Pin hole on the back. Do this while the device is powered on and you will get an orange light and you will know this has been done Ok.
Next plug the router into your computer using Ethernet cable.
Open internet explorer and type in the address bar http://192.168.0.1
Username: admin
Password: password
You will see an option for Setup wizard on the left.
Follow the on screen instuctions.
Apr 26, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Need to locate the correct driver for WNDR3300 Resource CD
Routers do not need drivers. They work by themselves. The computer does not control them.
If you have the router plugged in and all its lights are on then it is working. All you have to do is to get the computer to talk to it - and that doesn't require any CDs at all.
Feb 02, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Netgear WNDR3300 wireless mode lights not working
Before diagnosing it to be a hardware failure, I would suggest you to upgrade the firmware on the router. Follow the below steps to upgrade firmware on the router:
A. Open the router page using the following way:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
B. Visit the following link to download the latest firmware.
http://kb.netgear.com/app/answers/detail/a_id/12689
C. Please follow the steps to upload the firmware of the router:
1. Open the router page using the steps mentioned above.
2. Under Maintenance, click router Upgrade.
3. Click Browse and locate the upgrade file.
4. Click Upload.
5. Wait for the router to reboot.
6. Click on 'Logout' (at the bottom of the list) from left menu.
7. Reset and reconfigure the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 07, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
All lights on except green test light computor says your connected but browswer cant find page
Disconnect router power plug-in for 10 seconds and plug back in. It should work fine after about 3 minutes. They tend to build up a static charge once in a while.
Nov 17, 2009 | NetGear DG834G Router
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Blinking wan light
AngeloVal:
If you have internet connection and a solid security over the router I would't worry about it. In any case it does not hurt to read the manual and description to understand your product in detail: A perfect description is here:
http://kbserver.netgear.com/kb_web_files/n101186.asp
Hope that helped!
Dec 10, 2007 | NetGear WGR614 Router
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
249 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
