Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Low water pressure at water dispenser
Our water pressure coming out of the dispenser is very low. How to remedy? the ice maker works fine. i have noticed that it is time to replace the water filter. Are the 2 issues related?I have the same problem. One thing I notice is that when a new filter is installed, the water shoots out rapidly for a few seconds. Then the flow drops off to nothing as air is purged from the new filter. When the flow resumes, it is back to the very slow rate.
  • bigfishpk Jul 02, 2009
    When we moved, we unplugged the refrigerator and defrosted it. The problem did not go away. I guess that means it is the evaporator coil but I won't know unless I replace it. Sounds like a lot of headache if I do it myself and hundereds of dollars for the appliance service. I suppose this refrigerator is not as reliable as I thought so if you are looking to buy one, choose another brand. If you already bought one and have this problem, it is too late..
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The ice and water dispenser makes use of the cooling system of the refrigerator itself. If the freezer and refrigerator sections are operational as expected, then there would be nothing wrong with any component(s) directly related to the cooling system.
The basic design of ice and water dispenser follow the same principle. Both dispensers share the same inlet pipe for the water, the same filtration system and only splits up with a dual water inlet valve kit. If it were a filter problem, then the issue would be with both the water and ice dispensers not only with the water.
The only difference with the 2 systems is that in the ice dispenser, the incoming water is frozen while in the water dispenser, it is only cooled down. From the filter, the incoming water passes a dual water inlet valve kit.  This serves as electronically controlled valves that allows water to flow on either or both the ice dispenser system or the water dispenser system. This could be then a suspect. There would be a possibility that the valve for the water dispenser is restricted, partially blocked hence the limited supply of water. Another possibility is the water line from the dual valve leading to the water dispenser system is partially clogged, kinked.
Based on the above, possible faults could be with the dual valve or the water line.
Good luck and thank you for asking FixYa.
Posted on Jul 07, 2009
    Sergeant:
  • 326 Answers
On the back of the freezer there is evaporater coil normally some ice gets collected there,but if too much ice gets collected in the evaporater coil the ventilations gets blocked and this problem occurs.
the solution for this problem is simple.defrost the unit for 48 hours by making it empty completely.then check out in next 12 hours the problem will be solved.but if same problem occurs then its the problem of evaporater coil that needs replacement.
you can get evaporater coil at
www.repairclinic.com
this will help.
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 09, 2009
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
How to know the water pressure is wright for Samsung ice maker imc701
Used machine? If new seller needs to help. If under warranty check the MFG customer service number.
If used this may be the reason it was sold. If Used there is a possibility the water filter needs to be replaced. Yes they'[re expensive, but they can interfere with the process. Does the Cold water device work? Is there plenty of flow? If so it's not filter or pressure. If it barely comes out, then it's probably filter and may be the ice maker issue.
Feb 27, 2015 | GE GFSS6KKXSS Bottom Freezer French Door...
My Maytag ice maker stopped working; ice on doors & draw; What do you think might be causing this?
As odd as this sounds, my Maytag MFX2570AEM stopped making ice. I could feel ice in the tray but it suddenly stopped ejecting or making more even when the bar was in the correct position.
I read many articles telling me the motor was dead, the gears for removing the ice from the tray needed to be replaced, etc. THEN, I read one person who responded that his issue was resolved with a HAIR DRYER. It turns out something about the unit had frozen due to water getting on it, etc.
Sure enough, after blowing a hair dryer into the ice maker for 5-7 minutes I replaced the ice maker drawer and in about a minute it ejected the ice and filled the trays with water again. It has been making ice ever since.
Jan 31, 2015 | Maytag Refrigerators
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
Ice machine not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
The fan at back does not come on. The fridge make a clicking noise, The fan tries to run... Also it does not pump water anymore. It does make ice
  1. Dispenser switch
  1. Door switch
  1. Feeler arm
  1. Ice maker heater
Aug 16, 2014 | GE GSS22JER Side by Side Refrigerator
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Apr 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
83 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
