Question about Refrigerators
LIght is out in freezer. How to replace and can I do it myself?
Light in freezer is out, how to replace? Where to find replacement bulb? Can I do it myself? Help. Thanks.
  • Rose8280 May 09, 2009
    Thank you actually, the bulb is in the back by the ice maker and I can reach it, but tough to unscrew since it is in the freezer. Any tips to getting it to loosen without breaking?
    Thanks to both of you! We got it out, very easy actually but we appreciate the quick answers and will locate a replacement bulb. Have a great weekend! :) This site is great!
  • 67 Answers
Yes you can do yourself
Usually in a medal frame - use screwdriver to pry gently away - inside is a module with bulb - a number will be on it - just take out and insert new one and put frame back
You can obtain at an appliance parts store or on ebay usually (mine costs about $10-$12 at appliance store.)
I thought you meant the power light on freezer but
on reading it again looks like you mean in freezer - same idea but it's more likey a fridge / freezer bulb - just take off the panel and take your sample to a lighting or hardware store or contact manufacturer on their website if it is an oddball bulb.
Posted on May 09, 2009
    President:
  • 1,489 Answers
Yes, you can do this yourself.
There is probably a cover over the bulb which snaps off or has a coupla screws in it. Remove cover, unscrew bulb. You'll find a replacement at your grocery store (like Pathmark,etc.)
  • Samuel Charles Spriggs May 09, 2009
    Pardon me for asking, but could you rate my response as well, or did I give you the wrong answer?
2 Suggested Answers
arikrom
  • 528 Answers
SOURCE: Replaced light bulb, still not working, also
the control panel need to be replace :( not so cheap but it happen to me also.
Posted on Jan 01, 2010
How do I replace Maytag freezer light
You will need to post your model number. Thanks
Feb 01, 2015 | Maytag Refrigerators
How do I replace my freezer light
An owners manual I found online says:
Freezer
  1. Pinch rear tabs on light cover and pull straight down.
  2. Remove light bulb.
  3. Replace bulb with appliance bulb no greater than 40 watts.
  4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Aug 05, 2014 | Amana ARB1917CSR Bottom Freezer...
Sub-zero 550 with burnt out light bulbs in freezer, can not figure out how to remove them and replace.
Open the freezer drawer, the light bulbs are not covered, just hidden. If your able, get on you hands and knees, with the drawer open, look inside and up, the bulbs are in front on the top of the freezer compartment and can be unscrewed to replace. The above comment meant is you have issue to preform the task of being on your hands and knees, then laying down could help. As I get older it becomes more difficult to even change a light bulb somedays.
Good luck
Jul 23, 2011 | Refrigerators
Bulb quit working replaced with new one still doesn't work
The bulb still not working after replacement, this means the new bulb is working, but its not getting power.Either is short in the wires connecting to the bulb socket or the bulb/ light switch is faulty.In most of the cases, the switch gets shorted internally and , this causes the problem.Get the connections in the switch and to the switch checked, by meter as well as visually.This will confirm the problem.--------- This should help.Thanks.Helpmech.
Apr 05, 2011 | Kenmore 64802 Top Freezer Refrigerator
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Replace a burned-out bulb or headlight on a 2003 Toyota Camry XLE
I have similar issue with my 03 Camry XLE. I replaced the left side headlight bulb and the light still not coming on. Thanks in advance for the help.
Dec 06, 2008 | 2003 Toyota MR2 Spyder
Replacement interior bulb socket
First off its the repair mans problem not an electrican, he probably knows its a hard job and does not want to do it, probably be alot of work to replace it, check with Victory an see it a replacement part is available an ask how hard to replace.
Nov 11, 2008 | Victory Freezers
Interior light
No. If you see that the bulb was burned, you can replace it yourself, you dont need to take off the battery terminal since taking it off might cause more trouble to your car. dont worry you cant be electrocuted by a 12V dc by just replacing the bulb
Oct 20, 2008 | 2004 Toyota Corolla
Refrigerators Logo
251 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
