Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman riding mower - engine dies when releasing the clutch
Engine starts fine with clutch engaged. Engine dies when releasing clutch OR engaging the mower blades. Belts appear to be working. Cannot move mower forward or back when engine is stopped. Otherwise runs great. Seems like could just be a minor problem with a part that has broken.
  • 3 more comments
  • melbrizzi May 09, 2009
    I can check the carb but it was very recently cleaned. It also dies with the clutch engaged and engaging the blade so why would the carb be a problem in that case? The back axle does appear locked as I cannot move manually. The brake lever (the kind you lift up to lock in while holding in the clutch/brake) is not engaged but there is lever at the very back end of the rider that no matter whether I pull though and engage in the slot or leave out I cannot push the mower? Seems like something mechanical to me but I am not that knowledable on mowers.
    Not sure I posted my follow up question correctly so here it is again. I can check the carb but was just recently cleaned out. Engine also still immediately upon starting to engage the blade with clutch still engaged. Its true I cannot roll the mower when stopped with either the "latch" at the back end of the mower either engaged in the slot or not. Thus it feels like a mechanical problem but I am not that good with mowers. ???
    What do you mean by "drain my pocket" I assume you mean this is just something serious I should have a mower repair person look at rather than doing it myself? Thanks
  • melbrizzi May 10, 2009
    I don't have the model but it is a basic Craftsman with a Kohler engine. The clutch/brake is bottom left foot. The forward/reverse is on the right rear wheel well. There is another large lever on right to lower the deck. You engage the blades by lifting up a lever on the "dash". Other than that there is the key start on the right side of the dash and a choke knob and throttle volume lever on left side of dash. That is the mower. We have used it several times to mow this year and have not used it to plow snow. A couple times it did not want to go forward when in forward gear but pulling it into neutral and putting it back in forward did the trick. It starts no problem but the issue of dying soon as you start letting off the clutch/brake or even holding in the clutch and then trying to engage the blades will also kill the engine. It is at a relatives house now so can't just run over to get the model number. Thanks for any help before I just call someone to come out.
    Thanks and please see my reply
  • 1,000 Answers
Mel,
Nothing worse than to have your mower quit when you are ready to cut the grass.
Do you have a model number I can review, it would be very helpful and is this the first time this year you have attempted to mow?
Do you use the mower in the winter to plow snow.
Let me know.
Best Regards,
Posted on May 10, 2009
  • 413 Answers
Kindly take it to service station before it becomes serious issue
and drain your pocket
Posted on May 09, 2009
  • 11,896 Answers
If the engine dies when clutch is released, either the carb is plugged or dirty not letting the motor hit high power, or you may also want to check rear axle to make sure it is not locked up. Make sure brakes are not stuck ON.
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does engine die when brake released or mower engaged?
The first thing I would check is to make sure the drive belt is not binding somewhere.
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Oct 19, 2009 | Craftsman Garden
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
604 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
