Try the ACER support center in Bangladesh for warranty work
Bangalore - India Acer Customer Service Center C/O Compherals 2A Alsa Glendridge 32 Langfort Road Banglaore – 560025, India Tel: 1-800-11-6677 Fax: 91-80-22296068 cheers
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
1.)Turn on your BT on the 8300, 2.)Press and hold the button on your H700, flip open the boom when the light turns blue. 3.)On Blackberry go to BT setup and select search, it should find it. 4.) when it askes for the PIN enter "0000" and OK it should then be connected.
You either supressed the button under the ball in, and its going to need to be sent in for repair.
Or
Try this:
Rubbing alcohol and a cutip and rub it all over your trackball, if there is some dust that may have got caught under the button, hopefully the rubbing alcohol cleans this and releases the button.
Try it out let me know, Cheers,
It's a clear and fully detailed guide on how to unlock a BlackBerry curve 8300:
1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (if your BlackBerry have touchscreen) 7. Type MEPD ( you will not be able to see what you are typing ) 8. Type MEP2 or MEP4 ( you will not be able to see what you are typing ) 9. Now the phone will prompt you to enter the mep code 10. if you not already have the code, then i suggestBlackBerryMEP.COMto get it from . 11. Enter the mep code ( you should see "code accepted" ) 12. Restart your BlackBerry .
unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,both are safe way to Unlock your Blackberry 8300.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:) Best of Luck.
