Display caller id before pickup
My caller id does not diplay on my norstar M7310 until I pick up the line, is there a setting to show the incoming # before picking up?
Talk to your phone service provider.
Posted on May 13, 2009
Why doesn't one phone in my norstar meridian m7310 phones is not displaying caller id
Either COPY the config settings from a set where it works to those that don't, or on the sets that do not:
F**CONFIG, Terminals&Sets, (enter ext #), ... Telco Features, 1st Display Name: change between Name, Number, or Line.
And remember that some callers (esp Cellphones) do not provide Name info, so if the incoming calls at that extension are mostly from the same #s, it might be normal.
Aug 11, 2014 | NorStar Meridian M7310 Phone
CANT GET CALLER ID TO WORK ON NORSTAR M7310 PHONE IS IT CAPABLE
This feature requires a class trunk card in the phone system to pass Caller ID.
Jan 17, 2013 | NorStar M7310 Corded Phone
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
M7310 + Caller ID
You need CID service from teoco, Caller ID capable circuit packs in your Norstar system and 2 parameters turned on in programming under "terminals a & sets" for each extension. Also the CID will only auto display on sets that have the ringing turned on for that line. (you can also program a display button..feature-811). I doubt it is the software version but to display it go into programming and step down through the menu from 'Terminals&Sets' 10 items to 'Maintenance' and press 'show' then show again at 'System Version' this will give you a display like "SP: 30DHC04 NAT". Hope this helps. Bill C. www.dyns-tech.us We also do remote programming on Nortel CICS and MICS so equipped
Mar 15, 2010 | NorStar M7310 Corded Phone
Caller ID does not work until call is answered.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
Sep 24, 2009 | NorStar M7310 Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Can somebody help me in setting up caller ID on my Nortel Norstar M7310
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
that should do it providing you have caller id service though your local telco provider.
Mar 26, 2009 | NorStar Meridian M7310 Phone
Cid on display
Depending on the software, you can either have all the phones that are ringing to display caller id... or just one.
If the phones are set to ring and appear, but they are not displaying CLID infomation, you can hit the FEATURE 811 to toggle between name and number.
This should give you calling line ID, so long as it's enabled.
Feb 18, 2009 | NorStar M7310 Corded Phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
99 people viewed this question
k24674
jasbo
jasbo
