Question about Garden
Briggs & Stratton lawnmower wont start!
I unknowingly drained the old fuel out of my Briggs& Stratton self-propelled lawn mower caburetor side down. When I ran the engine, I got white smoke and then it shut down. All of my attempts to restart have failed. I read an earlier post and changed the oil per instructions. I replaced the spark plug and tried it again. I pulled the spark plug again and noticed that it was covered in oil. I cleaned it, dipped it in a little gasoline and tried it again. No luck. Please advise.
  • AddW May 11, 2010
    What do you mean by "carburetor side down".
    Have you tried several start attempts with the spark plug out so that the cylinder can be purged of the oil or whatever that may be causing the problem?
  • 82 Answers
I agree. you have oil where it shouldn't be. Remove spark plug and pull the rope a few times clean the plug and install it again.
Posted on May 09, 2009
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Starts then stops
a plugged jet inside the carb
Aug 27, 2012 | Briggs & Stratton Briggs Stratton...
Where is the oil drain plug
The drain plug on a Briggs and Stratton engine is underneath the deck. Most likely it is concealed by cover for the self propel belt and possibly the blade as well.
The suggested method for draining the oil is to warm up the engine by running the unit for 10 minutes or more, though this should be sufficient time for the engine to have warmed up. Then drain the oil.
An alternate method is to drain the oil out of the oil filler tube. To do this, after the engine is warmed up, tilt the mower onto the side that has the oil filler tube. Put the drain pan under the filler tube, then remove the filler cap. The oil will drain out into the oil drain pan.
CAUTION: The oil that will come out of the engine will be HOT! So be careful when removing the oil filler cap.
I hope this will answer your question. Best of luck in this mowing season.
Apr 04, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
My lawnmower starts but does not stay on
If it starts and runs and then slowly dies, it is more than likely your carburator jet is stopped up.With it being blocked, it is starving for fuel. You will have to clean out the carburator and retest. Also check your engine compression.
Jan 17, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
370 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
