Question about D-Link DGL-4500 Wireless Router
D-Link DIR615 power light doesn't come on when plugged in
My wife's uncle gave me a D-Link DIR615 router and without the power cable and foolishly enough I went out and bought one on the net for $18.00 thinking I'd save a bit on the router. I should just have bought it new for $39.99 but when I plug it in none of the LED lights display, most importantly the power light. Does this definitely mean the router is garbage? Is all I can do trash it? Please any help would be much appreciated. Thank you.
  • leonidtreyge May 09, 2009
    The input of the router is 5V,3A and the supply output I got which specified it's specifically for this router is 5V,1A. Does that mean anything?
  • Carl Navarro
    Carl Navarro May 11, 2010
    It depends on how well you can read. What was the output of the 5v power supply you bought for $18?
    If you bought the wrong one, yes, it looks like you turned a $40 router into a $58 one.
    Genius:
  • 1,268 Answers
You must have checked in the first place the voltage input of the router. Some router use 12V and others use 9V. Now if you have supplied an incorrect voltage input, you might fry the router's main board. Double check the voltage input of the router first vs. the adapter's output. If they are on the same voltage, your router is dead already
Posted on May 09, 2009
  • 2,460 Answers
Quick, what's the difference between 1A and 3A?
No, you didn't fry the unit, you just don't have enough power.
Carl
Connect magic jack
WHAT MAGIC JACK DO YOU HAVE IF YOU HAVE THE PLUS TAKE THE MODEM PLUG INTO THE MODEM AND TAKE THE OTHER END AND PLUG INTO THE ADAPTER THEN TAKE THE PHONE PLUG AND PLUG IT INTO THE PHONE ADAPTER AND THE OTHER PART INTO THE PHONE
Feb 01, 2014 | D-Link Dlink Dir-615 Cable/dsl Router...
How to create wireless bridge
DD WRT is a firmware upgrade sight you can find wonderful firmware upgrades that make your router come to life and Evan worth more than you payed for your original router, check the router database and see if your router is listed and capable for an upgrade to dd wrt, i did it with my dir615 and it gave me a whole host of additional optins for configurations , it was a long search for "dd wrt" but well worth it.
Oct 12, 2013 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Problem with TP-LINK TPLink Tp link Tl wr940n 300mbps Wireless N Router I was using the router just fawlessly over the weeks and today it just stopped working... it doesn't indicate any wifi signal...
Try to power cycle the network. if still exists then upgrade the firmware of the router , reset it and reconfigure it.try, it might solve the issue.
Dec 23, 2012 | Computers & Internet
I keep getting kicked off
Try changing your wireless channel to 1 or 11 to see if that resolves the problem. You can access the router page if you need help logging into your router.
http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
If that doesn't work, I think calling them is the correct course of action. number is 1-800-255-3700. they are open from 6a to 7p PST, seven days a week.
Jun 12, 2012 | D-Link Dlink Dir-615 Cable/dsl Router...
I mistakenly plugged in 9V power to my D-Link DIR615 router?
Most likely you have damaged the D-Link router.
Connect a correct power adapter to the D-Link to see if it works properly, if it doesn't work then you need to purchasr a new wireless router.
Feb 26, 2012 | D-Link DGL-4500 Wireless Router
I have a D-link DIR615 Router/switch. Intermittently (i.e. several times per day) the router looses connection to the internet (although the internet connection light stays green), or I loose the local...
Download and install the firmware update
http://www.dlink.com/products/default.aspx?pid=DIR-615&tab=3
Make sure to download the one for your specific model, and do the flash via a wired connection.
If no change, most likely a new router is in order
Jun 20, 2011 | D-Link DIR-615 Wireless Router
How can i setup my router
Thank you for using FixYa
Plug in the ethernet cable to the back of your computer and the other end into the modem. Turn the modem and router on.
Put the CD into the cd player and type in
D:\DIR615.exe
Click - Install router - and follow the instructions on the screen.
If the cd is not available type in 192.168.0.1 into your browser and put in the password "admin" then select - Setup Wizard
(Here is a link to your manual for more information.)
ftp://ftp.dlink.com/Gateway/dir615.../Manual/dir615_revC_manual_300.pdf
Since we do not know at this time if you have a cable modem or a DSL modem, or if you are Static or Dynamic or what protocol you are on, following the Wizard is your best bet. Further, you ISP should be able to hook you up if you contact them.
I hope this was useful and please comment if this was helpful to you.
Mar 25, 2011 | D-Link DIR-615 Wireless Router
Just got a dir615 from virgin media. lan to pc not working
If the lan light does not light up, there is a problem with the connection between the pc and the router. Did you use the cable between your modem and your pc as the cable between your router and your pc? If so, it may be the wrong cable. With some modems the suppler sends a cross over cable. This will not work between your router and your pc. Get a straight through cable and try that.
If that does not work, we need more info to help you more.
1. What is the IP address set to on your PC. See the TCP/IP properties listed in your network connection properties in the control panel.
2. Does your PC work with the modem directly?
3. Does the cable you are using have a cross-over label on it?
4. Are you trying initially to connect to the router via a wireless connection? You should use a cable connection to set up the router, then try the wireless connection.
good luck, and if any of this solves your problem please leave feedback. Otherwise send more information.
Feb 05, 2010 | D-Link DIR-615 Wireless Router
When my computer is connected directly to the modem, i am able to obtain internet. However if plug the enthernet cable from my computer into a Dlink DIR615 router in the hope of creating a wireless...
Make sure your modem is plugged into your WAN port on your router and your computer is plugged into your LAN port on the router, then turn everything off (unplug what doesn't have a switch) then turn the modem on first and let all the lights come on on the modem, then turn the router on and let all the lights come on on it then turn the computer on. Don't turn the next item on until the previous item has all the lights on that are going to come on.
Good Luck
Nov 29, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DGL-4500 Wireless Router Logo
1,206 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
