Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine Sputters and pops
Craftsman 21.5 HP 42" deck Model No. 917.272463. Upon startup it now pops every second or so. After running for 1 minute sputtering or popping disappears until I begin moving forwards or backwards. Popping is slightly less frequent when moving. I've replaced the spark plugs, air filter and gas is fresh. Fuel filter was replaced Spring of last year. Found fuel line that was cracked and replaced it. Found hole in vacuum hose and taped it till I get a replacement. Any ideas or suggestions is greatly appreciated.
  • kam0993 May 09, 2009
    I placed duct tape (which fixes everything, lol) around the hole and sealed it tightly. However, it still pops. Does this mean air is getting through the tape or could it be something else?
    Novelist:
  • 130 Answers
Its the problem of vaccum hose in the unit.clear problem of vaccum hose.as the required pressure to start up is not getting created due to vaccum leaking from the hose the air is leaking from it somewhere.pack it tightly .but till you get new part.you will have to pack it tightly for temprory use if required. its the vaccum hose problem.
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 09, 2009
  • bepositive May 09, 2009
    the air is getting through the tape .you will need the part as the pressure of air ios too high while start up.
    the problem is vaccum hose.
    keep updated.
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Was running after oil change ,and it just died .now it wont start?
take out the spark plug then plug it up and hold it agains the frame or somthing metal and crank it over if it sparks your getting fire
Feb 27, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Have craftsman 21 hp 42"cut
You can take the model number listed under the seat and go to search craftsman parts, go to the sears website and use that 917.# and you will be able to see an exploded view of the deck among other sections of the mower, all other sections except the engine.
I hope this helps.
Aug 17, 2011 | Garden
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
