Question about GE DCL333EA Dryer
Stopped and won't start. Very hot (overheated). Lint was full, now empty.
Stopped and won't start. was very hot. lots of lint in trap, now cleaned out
    President:
  • 1,489 Answers
Sounds like your vent hose and/or vent flap (on the outside wall) is clogged. Caused heat to backup in dryer, overheated it -- if it doesn't run after cooling down it's probably a thermal limit fuse in the heating element circuit which is blown and will need replacing.
Clean hose.
If you don't have experience with repairing appliances, I'd call for service.
More help?, let me know.
Posted on May 09, 2009
    Problem Solver:
  • 11 Answers
Either the belt or capacitor
Dryer gets warm but not hot. Takes much longer than used to.
A lot of times when this happens, the are vent is plugged up, had one that did this and come to find out it was plugged up so bad it stopped getting hot. hope this helps.
Dec 01, 2015 | Dryers
Our Dryer won' take all of the lint out of our clothes after the drying cycle has finished.
The lint trap may be clogged and needs to be cleaned. Also, the clothing could be full of "lint" such as used tissue remnants after washing.
Feb 14, 2015 | Dryers
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
The dryer keeps stopping (the timer skips from 50 mins to 10 mins in secs) AND what worries me the most is, I haven't needed to empty the lint trap.
Well, well.
Am I to understand the timer dial is going really fast as you watch it?
I didn't know that was possible, but maybe the wiring has been compromised (shorted out) somehow. If so, you would need to take it all back apart and look for a wire that is pinched or incorrectly hooked up. Some Whirlpool dryers have numbers on the back of the timer that are supposed to match numbers that are actually printed on the wires themselves.
As far as the lint trap, perhaps one of the "pipes" inside the dryer is unhooked or loose causing the hot air to miss the screen.
Be blessed.
some were he has blocked the out let for lint trap the reason its stopping is its over heating don't use untill sorted it will cause a fire if left
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer not drying, appears to be heating
Jan 28, 2010 | GE Dryers
The cycles have stopped heating. We have replaced the thermol fuse twice now in two weeks. Noticed when I touch the button to start a cycle, the readout is saying to check filter. Where is that? I'm...
Go outside and look at your flapper valve. Here is another news flash the lint filter can be clean but the air ducts in the dryer can still have lint build up in them. Pull out the lint trap also then using a flaishlight look underneath and around the lint trap area for lint build up. If you don't see anything there remove the rear vent hose and look both into the dryer and into the vent hose. Most likely you find either a kinded vent hose or lint buildup somewhere other than the lint trap itself. If you do find the source just do not use anything sharp to attempt to remove the lint. A bent metal coat hanger or a very large zip / spot ite works great for this task. Hopefully this will resolve your problem. If not post back and we can go from there.
Jan 14, 2010 | Dryers
Dryers Logo
107 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
