Question about Frigidaire FRT15G5CS Top Freezer Refrigerator
CRAB SMELL I have a samsung side-by-side with dual compressor. I had some imitation crab in a drawer-went on vacation and the smell is all through the refer only. i have cleaned with vinigar, bleach. Now i have kitty litter and newspapers in it. The refer is empty. Any other suggestions as the smell is on everything and when you touch things your hands smell like crab!!! Thanks in advance for any help you may give me. BONNIE
SOURCE: Odor will not go away.............
try vinegar or clorox
Posted on May 13, 2008
  • 4 Answers
SOURCE: There is a sour smell that comes out of the bottom
There is drip tray underneath the unit. Depending on model, there are multiple ways to access. This tray needs cleaning regularly. Once clean, sprinkle in Baking Soda to keep odors down. Cleeaning this on a regular basis is the only way to beat this smell.
Posted on May 16, 2009
  • 197 Answers
SOURCE: How do I get rid of the musty smell?
If you know someone who owns a bar, ask them for about 1/2 pt of line cleaning fluid. Start your machine on a 60o wash (empty) and as soon as the water starts flowing into the powder drawer, slowly pour the line cleaner into the water flow. Let the machine go through it's normal cycle, then run the same cycle programme as soon as you can (immediatly if possible) using clean water. Following this action, get your finger and rub it along the inside of the drum, if it's squeekly clean it's solved, if it feels slightly slimely, run the water only wash again the completly to remove any further residue of the cleaner. The smell should go. Let me know how you get on, Regards Dave.
Posted on Jul 17, 2009
  • 57 Answers
SOURCE: The fabric softner isn't draining during cycle but
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly. This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Posted on Dec 11, 2009
  • 1891 Answers
SOURCE: A bag of crab legs leaked how to get odor out and
it does have a drain but it's not for this / to clean it use hot water and a tukey baster . the hot water will clear the tube and algi ect . mm the odor is best removed with baking soda. / wash it with soda and leave a box in the frig . mm
Posted on Aug 11, 2010
There's a rotten smell in my Samsung Frenchdoor fridge with two drawers. We have cleaned the inside thoroughly
lots of others samsung with this problem...
https://www.cnet.com/forums/discussions/strong-smell-in-french-door-refigerator-567468/
several different fixes take your pick.worked for some not all though.
Sure hope this helps a little.
Jan 13, 2018 | Samsung Refrigerators
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
Think our refridgerator motor went smell of smoke but is still cool will it burn
Check to see if your condensor fan motor is running, should be behind the refrigerator backing plate and close to your compressor. Usually caused by a very dirty condensor unit. You have to vacuum, brush or blow out the condensor coils at least once a year to prevent overheating damage and to save 100.00 to 300.00 a year in electricity. If this is not the problem then let me know if the smell is coming from inside the freezer, refer section, or underneath.
Appliance Specialists
Dec 10, 2009 | GE GSF25XGR Side by Side Refrigerator
Samsung RS2545 side by side refrig, the drawers in the refrig seems to have ice built up behind wall that is pushing the drawers out too far.
Because your refrigerator has dual evaporators you can start by defrosting. Yes the old time defrost. Once the ice is gone on the refrigerator side lets try slowly adjusting the fresh food sections to temps acceptable to the foods safe temperatures. I will send you the service manual but if a sensor has malfunctioned you may need to call or order parts. Sea Breeze
Jun 27, 2009 | Samsung Refrigerators
Neither refrigerator nor freezer cooling.
sounds like the compressor or relay went out. if the compressor is hot turn off and let cool to room temp. and try it then [a few hours] , if it is not hot then replace the relay on the compressor.
Phil
Jun 10, 2009 | Kenmore 52582 / 52584
Bad Compressor, valve sticking in the compresser
Contact Whirlpool Customer Care about this. There has been a serious problem with the Embraco compressors they are using.
May 15, 2009 | Whirlpool GD2SHGX Refrigerator
Filter indicator on samsung side by side fridge freezer is on
2 places filter can be top left upper corner of fridge or behind the fridge with a little longer filter type
the smell could be the filter but i would pull all drawers and shelves and i would check for mold also the possibility of water leak behind panel of water spout that has molded over this smell you could never forget cause smells like old gym socks
Apr 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRT15G5CS Top Freezer Refrigerator Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
