Question about Saeco Royal Professional Espresso Machine
My Saeco Royal Professional
I purchased this machine in January--- 9 mos. old.  It suddenly (out of the blue) stopped making large coffees.  Instead, I have to touch the middle size 2x to get more coffee.  what's wrong?
  • Red Hatski Oct 13, 2007
    THANK YOU THANK YOU THANK YOU.  The first option solved it!!!  I had thought that  would have a major computer problem.
    Yeah!
    Sergeant:
  • Saeco Expert
  • 223 Answers
Okay! This can be 1 of 2 things.
1. Your machine button needs to be programmed. Do this by holding the button down until the coffee is dispensed to the height of your likeing, then let go. The button should now be programmed.
2. Your machine is leaking internally and some of the water that should be going into your cup is going elsewhere.
Also try descaling your machine. For more info go to: www.cerinicoffee.com
Posted on Oct 12, 2007
SOURCE:
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
Hi. When I try to make a large cup of coffee, the machine makes more like a medium size cup. What can I do to fix that and get a true large cup? Thanks.
Hi!
When making a cup of coffee hold the button in until the coffee reaches the height you want then release button. You can set the 3 sizes in this manner
Ray AU
Feb 09, 2011 | Saeco Royal Professional Espresso Machine
Mty Saeco Royal expresso machine will not warm up. What might the problem be?\r\nh
where can i purchase a motherboard for my saeco royla profesional type sup016e
Aug 29, 2010 | Saeco Royal Professional Espresso Machine
Excessive water poured through shot
its possible someone held the buttons down to long enabling program mode.
Go to your local market and purchase a 3 ounce measuring glass. Place it where you place your coffee cup and hold down the small button, it should enable program mode. Stop it once it reaches 1 ounce or your desired amount.
Do the same for the large.
Sep 03, 2009 | Saeco Royal Professional Espresso Machine
Saeco Machine needs looking at...
you here the grinder motor if yes the grinder might be full of old coffee stuck on the theth where it grind be carefull with our hand push the coffee bean while making a expressoyou force the bean to go in it will clean the grinder it get cloaged oily coffee use or old coffee pierre
Dec 07, 2008 | Saeco Royal Professional Espresso Machine
Problem with Saeco royal digital plus
Try replacing the O ring in the brew unit
Oct 27, 2008 | Saeco Royal Digital Plus Coffee...
No power -- where is fuse?
Fuse is inside the machine. Looks like a black wire thats fat in the middle.
Its either that or the main board blew. I pray it is the fuse because saeco doesn't sell the royal boards anymore from what i understand.
May 26, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
143 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
