Question about Maytag MDG2706A Gas Dryer
No heat, exhaust clean and gas flow good.
I have a Maytag Gas Dryer Model #MDG8600AWW. No heat coming from unit. Wondering how to access heating element?
  • 460 Answers
I hope this helps U
copy n paste http://www.partselect.com/ModelFrames.aspx?ModelID=153823&ModelNum=MDG8600AWW&ManufactureID=1&Selected=51311&Position=6&mfg=Maytag&Type=Appliance&Mark=6
let me know if this works for U
"Was this helpful?"
Posted on May 09, 2009
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
Mdg8600Aww not heating. Any ideas? (gas line is on)
This tip i wrote about what to check when your gas dryer doesnt help shoild help to seewhy its not heating. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 10, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
How to relight the pilot light maytag mdg8600aww
There is no pilot light on that model. It uses a glowbar style igniter. It could be several things causing no heat. Here is a troubleshooting video that should help http://appliancehelponline.com/gdryertroublevideo.html
Aug 08, 2010 | Maytag Atlantis MDG8600AW Gas Dryer
Maytag Gas dryer not heating, Model #MDG8600AWW
Called Maytage directly, information is free. Thanks anyway
Jan 13, 2010 | Maytag Dryers
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Mar 28, 2009 | Maytag MDG2706A Gas Dryer
Carrier Natural Gas Pack: Smell & Soot on exhaust tube
Time for a good cleaning. Make sure the heat exchanger is in good shape and is getting good heat flow over it to the exhaust. The odor may be an indication of a restriction in the heat exchanger, the flames are hitting something, improper air or gas adjustment or a blower not coming up to correct speed. You can access the heating unit from a side panel. Look for the exhaust port and start with that panel. Wasps nests are predominant in these things.
Dec 19, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Maytag Gas Dryer MDG8600AWW does not heat up. Could it be the glow bar ignition? When the dryer was beginning to fail, it would heat up for a few minutes then the heat would die. Now it doesn't heat up at...
If it was heating occasionally after you first noticed the problem, most likely not the ignition glow element. I am having the same problem and am looking at replacing the gas valve. I used to be a Sears Repairman. I verified that both magnetic coils are energizing when they are supposed to, but often the gas won't flow. Also, I hear a clicking noise internally on the gas valve.
Sep 01, 2008 | Dryers
Maytag MDG2706A Gas Dryer Logo
323 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
