Mismatch of stereo receiver outlet to connector wire.
The connection wire provided to connect the Shift3 Indoor/outdoor speaker transmitter to our home stereo receiver does not fit the receiver. The receiver is an eighteen year-old Sharp. Is there an adapter available?
Debbie W
Sharp receiver serial no. 10910666
Shift3 indoor/outdoor speaker CEW110
    President:
  • 1,489 Answers
There are adapters available at Radio Shack for connecting almost anything to anything.
Not knowing which connectors you have, I can't tell you what to get, but if you take what you can with you and explain the rest, they should be able to give you the correct adapter.
Posted on May 09, 2009
I have upgraded my surround system with Marantz SR5008 hd receiver replacing my SR780. I want to use the SR780 for a "audio only" music system in my living room (2 Bose speskers w/ powered subwoofer) and...
You could use a Speaker Switch. You can find an ione at: http://www.bestbuy.com/site/4-pair-stereo-speaker-selector/9746779.p;jsessionid=A65E902544159CF276BC147D7BE1F696.bbolsp-app02-185?id=1218166511087&skuId=9746779&st=categoryid$abcat0107032&cp=1&lp=1#tab=overview
Mar 01, 2014 | Kenwood VR615 Receiver
Indoor unit and outdoor unit not connecting
If the outdoor transmitter and indoor receiver communicated for a time and now don't, it could be time for a battery change. The usual procedure is to change transmitter batteries first, then the receiver. You have to wait for something like 10 minutes for the units to begin to "talk". All of this should be covered in the instructions you received with your system
Oct 14, 2013 | NG Weather NATIONAL GEOGRAPHIC 265NC
Have outdoor speakers but will not play sound, they are connected to a xantech pa1235x and the indoor speakers work but not the outside ones
Check the reciever and verify if you have a selector swicth pressed for A speakers and B speakers and see if this helps...
Some recievers will only power A or B, not both at the same time.
Lets not assume your outdoor speakers work. Would be helpful to know if you have tried to disconnect the inside set and plugged the outside speakers in those stereo jacks. If no sound, your speakers may have loose wires on the inside of the box/cabinet/case or they could be no good period.
If they do work, and the system does not provide all four jacks to be powered at the same time. You may consider buying a pair of piggy back rca jacks. Plug in the indoor and outdoor speakers into the same connectors the indoor ones are on now.
That way at least you can run them all at the same time from the speaker connector where you have the indoor speakers hooked up..
Hopefully you'll find something useful in this
Good Luck
Respectfully
Jun 09, 2011 | JBL N24AWIIBLK Speaker
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
Sep 18, 2009 | Bose Indoor/Outdoor Speakers (Pair) -...
Can't figure out where to plug in the transmitter
if the unit your tring to connect has RCA style plugs you can plug them in to the tape REC out connections on the back of the reciever.
Once you turn the reciever on an select your source it will out put on the tape REC out which in turn sends signal to the wireless device.
if the unit your tring to connect has a 1/8" or 1/4" plug you have to convert to RCA or plug into the 1/4" headphone conncetion on the front of the unit
Jul 01, 2009 | Audio Players & Recorders
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
What is the correct speaker connection configuration for 5.1 surround and 4 outdoor speakers for stereo music?
Use a speaker switch box but amp may switch off at higher volumes.
Hope this helps.
CABLE GUY.
Apr 19, 2009 | Audio Players & Recorders
Wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Dec 30, 2008 | Computers & Internet
Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
116 people viewed this question
 Grubhead
Grubhead
