Question about Car Audio & Video
I have just taken out my factory fitted stereo in my mondeo and have tried to fit another head unit but there is no sound coming out of the speakers
  • 91 Answers
You have a factory amp, you need a aftermarket deck harness, it will plug into your factory deck wiring and then plug into your after market deck, your speakers will then work
Posted on May 11, 2009
I have an 02 ford explorer, the previous owner had a custom sound system installed. He took allof trhe custom speakers and amps out but left the stereo in,but it does'nt play. the stereo work ands powers...
sounds the like the vehicle had an oem amplifier that was removed, most after market stereo installers will trace the speakers wires individually by continuity to by pass the factory amplifier and wire the new head unit to the vehicles speakers, if the harness has been spliced or factory amp removed, you will need to check if the amplifier still exists (usually under passenger rear seat sometimes located in trunk area) and see if the harness has been bypassed. if so you will have to reconnect the harness by color code in order to use the factory head unit
Feb 18, 2011 | Ford Explorer Cars & Trucks
Model GCE7002 CD taken out of old car need to fit to new car but connection does not fit,can you advise.
Go to walmart, they'll probably have the plug that fits your car. If they don't an auto parts store will. The new connection will plug right into your car's plug but you'll have to splice the wires to connect it to your stereo unit. All you'll have to do tho is match colors. The wires that come out of the new connection you bought, and the wires coming from the stereo unit will match, just connect color to color and you're all set. note: you won't use all the wires coming from the connection. hope this helps
Oct 22, 2009 | Car Audio & Video
My radio doesn't work
It sounds as if you forgot to plug in the antenna.
Mar 21, 2009 | Car Audio & Video
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
I have recently purchased an rx8, but the previous owner had fitted an after market stereo which he took with him. I have 2 problems, i have purchased a double din system which i tried to fit. I was able...
If the unit was installed professionally no wire's will have been cut from factory harness. Yes you would need an aftermarket adapting harness so your speakers will work . Vehicle may also be equipped with a stock amp. be sure to hook remote wire on harness to head unit.
Dec 03, 2008 | Car Audio & Video
Hello i would like to add a din head unit a few 6/9s and maybe a sub if poss into my saab 9-3 vector sport 56 plate is it possible with my existing 7 factory fitted speakers so that when i come to sell my...
My suggestion is to go to your local audio shop and pickup a dash kit and wiring harness to hook up the din head unit. I actually wouldn't recommend putting in aftermarket speakers unless you don't plan on reselling or they are blown. You could hook a sub up by running your power wire to your amp like usual, hook your amp turn-on wire to an accessory wire and buy a "line level converter" you will tap into factory speaker wires with this and it will convert it to RCAs. You will only need to do this if you are using the factory head unit. Also, unless the aftermarket unit has features that you want that the factory one doesn't, I wouldn't bother with that either. Good luck. Let me know if you need any more help.
-Andrew Hawkins
Aug 28, 2008 | Car Audio & Video
New car stereo, after fitting the sound did nt come through although it switched on and the signal was working through the screen equilizer
khodor1huss- First of all who did the install,there is a good possibility that you are simply missing a wire that powers up the factory amp.What type of vehicle is it in,let me know and we can figure it out. cooltekMar,12/08
Mar 11, 2008 | Audio Players & Recorders
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
