Monitor has geen tint
Monitor has a green tint.
  • 355 Answers
Lost blue. 90% of these problems are a bad interconnect cable between
te computer and monitor. Very few are actual failures inside the
monitor. When it is a failure inside the monitor most are solder
connection failures.
There is usually very little that is between the cable and the picture
tube in most computer monitors. Typically you will have a fast
switch/buffer to insert the OSD, then a predriver transistor and an
output transistor circuits.
So the actual failure will need troubleshot while it is acting up by a
technician.
Posted on May 09, 2009
I have a blue green tint on my desktop Dell? SE198WFP Flat Panel Color Monitor, its a dell OptiPlex GX260 , I assume I had a bad monitor at 1st , I hooked that same monitor to a different desktop the...
This blue green tint appears when a magnet is close to the monitor. Find devices having a magnet which is close to the desktop. This might be the problem. Take devices having magnets away and i guess things should be fine.
Dec 28, 2010 | Computers & Internet
My Zentith D60WLCD has a green tint
some transitor is gone bad,you better send it for repair
May 19, 2008 | Zenith D60WLCD 60" Rear Projection...
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
Green tint
Sounds like the monitor cable has a short or loose connection at computer or monitor side.
May 24, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Green tinted screen
there is a Circle of Colourfull part in the monitor. it is getting break down. need to go service.
thanks to choosing FixYa.
May 28, 2009 | Acer X193W LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Can"t find white or comfortable background screen other than a light green that is hurting my eyes
If you have a screen that gets "tints" of various colors on a corner or edge, check that the monitor plugin cable is not near or laying on top of a power cable, the magnetic field around a power cord will cause a monitor to get strange tints or lines in the screen. Option two if the entire screen has a tint equally all over it is possibly the color is out of adjustment or failing - a technician should be able to adjust it internally.
Apr 29, 2009 | AOpen A75PF Monitor
Screen has a green tint
The instruction manual should tell you how to get into the menu for the monitor to change the color settingts. With a make and model number I can give you step-by-step instructions on how to change them.
Mar 18, 2009 | Computers & Internet
Can not adjust the color, color is geen
Try right-clicking on your desktop. That will bring up the Display properties. Click on the tab that allows you to set the colors. Set it to the highest amount possible. Reboot and your colors should be fine.
Dec 27, 2008 | KDS SONY -R50XBR1 (SONKDSR50XBR1) PC...
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
