Question about Troy Garden
Wont start will run only a couple of seconds after it is primed then stalls after repimed will run a couple of seconds, changed plug and filter any suggestions
picatudo
  • 239 Answers
SOURCE: runs for a few seconds then stops
there are two screws on the carburator one is for air other for gas .that need ajusment
Posted on Dec 31, 2008
Papa Chan
  • 56 Answers
SOURCE: 2003 GMC Duramax Diesel won't start
I see that you had the injectors replaced 20,000 miles ago. I would still check the oil to make sure it is not overfull. The new injectors could be bad. If the oil level is not overfull then get a paper towel and touch the dip stick tip on the paper towel while oil is on the dip stick. If it's only oil it will not spread. If it has diesel in the oil the oil with spread. If this test doesn't show the injectors to be bad then you have three other possibilities. The FICM (fuel injection control module), the fuel pressure regulator, or the injection pump. It's hard to pinpoint what the problem is without running more tests and the only way to run those tests is with the computer the dealership has. Just so you know your injectors are still under warranty until 100,000 miles. Most likely you will have to take it to the dealership to get you truck fixed. I hope this helps you some.
Posted on Jan 05, 2009
  • 246 Answers
SOURCE: can't start toro mower. cleaned spark plug , new
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 41 Answers
SOURCE: weedwacker starts easy but will not run for more than 5 seconds .
May need to check for holes in fuels. Or fuel pump diapham is bad. If so replace carb., don,t waste money on carb. kit.
Posted on May 13, 2009
  • 323 Answers
SOURCE: Have old Eager ****** 280 Gas Trimmer,
If the bulb is good and it still won't prime, then you have either one more tube (there are usually 3) to replace, OR, the gas pickup in the tank has a plugged filter or a plugged line. I'd check it first.
Sirwriter
Posted on May 14, 2009
Car wont start
First of all, I need info. Year? Engine? mileage? conditions? What all was replaced? By tune-up I'm assuming you replaced plugs/wires/cap and rotor/etc. On earlier Civics it is VERY easy to miss the coil tower with the contact pin while installing the dist. cap. And it's also easy to knock one of the wires off of the igniter/ignition module while doing so as well. Also, if you replaced the fuel filter, keep in mind you'll have to give it a couple key cycles to prime the new filter. Hope that helps. Post back if you still have a problem.
Apr 01, 2014 | Honda Civic Cars & Trucks
Will start but wont stay running
Keep trying, sometimes it will do this for a bit till all the air gets out of the system.
Dec 04, 2013 | Chevrolet Tahoe Cars & Trucks
Replaced filter and fuel pump on 2004 road glide know wont start
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Nov 08, 2013 | 2007 Harley Davidson FXDB Dyna Street Bob
I have a 2004 silerado 2500 hd 4x4 with a 6.0 engine. I hadnt driven it for a couple days and when I took it for a ride it started stalling on me. I got it home but it wont stay running. Most of the time...
When you say plugs I assume its a diesel w/glo plugs. This could only be a fuel issue; its either dirty or it has water in it or has lost it prime pressure. Dirty or watery can be fixed by draining the tank and changing the filter then flushing the line by opening the bleed screw at the primer pump and pumping it out till its clear/clean. If its the prime pressure then open the bleed screw, pump till there is no air, close the bleed screw and pump until the primer gets too hard to push. Hope this helps.
Oct 09, 2011 | Cars & Trucks
My 5 hp MTD mower keeps stalling after running for a couple minutes. I then prime it excessively and it will start back up and do the same again. I have cleaned the carb and replaced the priming needle,...
You probably have already done this, but I had a JD 111 rider awhile ago and did most of the things you have done with no success. Then I replaced the fuel line and "BINGO" it worked great after that. Seems the line had a weak spot and would **** closed when trying to start.
Good Luck
Jul 10, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
May 23, 2010 | Briggs & Stratton Power Products 1539...
Wont stay running
Bad fuel or check for water in your fuel! Clean your carb and float bowl. Empty gas into a clear container, if there is two levels of liquid one of them is water. Of course make sure you have good spark plug.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
Will start up run for awhile then stall and wont restart
Hello, I would start with a general tune up. Spark plugs and wires, Fuel Filter, Oil Change and Filter Change, Air Filter Change, Some injector cleaner would not hurt eirther. Be sure to lubricate your high mileage car and also use a farily good oil for your motor as well. The run for awhile problem sounds like bad spark plugs. I would change your spark plugs, wires, distributor cap, and rotarty button.
May 20, 2009 | 1993 Honda Accord
Runs for a few seconds then stops
Dec 30, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
79 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
