Question about Casio FX-115ES Scientific Calculator
Hi to use "STO"
How to enter and how to clear variables in this memory "STO"
when you made a mistake and do not want what is recalled
  • Casio Master
  • 8,073 Answers
Hello
You can store values in A, B,C, D, and M.
If you do not like the result recalled from a particular memory, Store the correct value in it. To clear the memories (default) store 0 in each of them.
Hope it helps.
Posted on Sep 12, 2009
  • k24674 Sep 12, 2009
    An exemple 18 [Shift][STO]A stores 18 in memory A.
How do I enter an unknown variable? Example 2(3x-4)
You have several variables but the only ones you have access to are the letters from A to F, the letters x and y, and the Memory M.
To store a value in variable x, enter the value, press [STO] followed by the key that has an x near it. To recall a value sotred in a letter variable press [RCL] followed by the appropriate key (the one that has a letter above it).
But you cannot do any algebra with this calculator, if that is what you are attempting to do. And please do read the manual that shipped with the calculator that is the best reference to the capabilities of the machine.
Sep 19, 2013 | Sharp el-531x scientific calculator
Hi & thanks. There is a small 'M' on the top center right of the 'number' screen. How do I get this to go away? Remove the battery? Thanks again & regards, -louis
This M does no harm. It merely reminds you that you stored something in memory. You can try pressing the AC (Clear All) button. Alternatively, store 0 in all the memories. If I am not mistaken you have 3 memories. Try
0 STO 1 to clear Memory 1
0 STO 2 to clear Memory 2
0 STO 3 to clear Memory 3.
Jun 29, 2011 | Texas Instruments BA Real Estate...
TI-89 Titanium: I'm trying to enter a problem in which I can define two variables. For example, I would like "x-y|x=1,y=2" to give me an answer of -1, but that format doesn't work.
You can use the = sign if it is in a Function or, program as a loop. But, to define it you have to use the [STO-] key. Or store key. As in: [1 ] [STO-] [X ] [ENTER]
Next, [2] [STO-] [Y] [ENTER]
Jan 06, 2011 | Texas Instruments TI-89 Calculator
How to store and recall numbers
Example:
Type 5 then ENTER.
Type ' (which is next to the STO button)
Press the alpha button (under the ENTER button) to type a letter or press it twice to put it in "alpha lock". Press it twice for this example.
Type F I V E then ENTER.
Your screen should look like this:
5
'FIVE'
Press the STO button.
To recall the number, press the VAR button. You should see the variable "FIVE" that you just created. Press the corresponding gray button that is under your variable. This will give you your number.
Oct 18, 2010 | HP 48gx Calculator
How to remove memory from scienfic calculator
To clear a memory location, just store 0 in it.
0 [STO] M clears memory M
0 [STO] A clears memory A
0 [STO] B clears memory B
etc.
Oct 13, 2010 | Casio FX-115ES Scientific Calculator
I do not know how to delete memory storage like m1 m2 my comp has ON/NC not ON/CO
When a memory ontains a number other than 0, M1, M2, or M3 displays.
To clear a single memory, press 0 [sto] 1, 0 [sto] 2, or
0 [sto] 3. To clear all 3 memories (solar only), press [On/AC].
Sep 25, 2010 | Texas Instruments TI-30XA Calculator
COMO BORRO LOS DATOS DE LA MEMORIA
To delete data from memory you store 0 in the memory
To clear Memory 1 (M1) store 0 in it
Para borrar la memoria M1, almacenar 0 en M1 (Google translate)
0 [STO] 1 clears M1
0 [STO] 2 clears M2
0 [STO] 3 clears M3
Sep 01, 2010 | Texas Instruments TI-30XA Calculator
How do you enter your variable?
The memory locations A,B,C,D,X,Y and M are available to store values in them. M is the constant memory.
To type the name of, say, variable X, you press the ALPHA key then the the key next to which is the X in cyan/Green color. If I remember correctly it is the key marked with a parenthesis ).
However to store a value in a memory location or to recall a stored value you use the STO key to store and the RCL key to recall. To store or recall there is no need to press the ALPHA key.
Jun 14, 2010 | Casio fx-300ES Calculator
After doing this division "7/4" I get the answer "1.75". I want to keep the whole number in one variable and the decimal part in another variable. What kind of program I could use to do that? Million of...
You may be able to find a program online that will automatically do what you want however if you don't have to do this too often you can just manually set "1" to a variable via the "STO-->" button (right above the "on" button-- select the value, pres sto-->, alpha and whatever variable you want) and set the ".75" to a variable.
Finding a program may be difficult for this type of program because you're trying to separate a whole number (essentially looking for a whole number and the remainder). You could always write a program for yourself but as I said before it might be a bit difficult.
Jun 25, 2009 | Texas Instruments TI-84 Plus Calculator
Memory and memory recal
The STO> button just above the on/off button is your memory store initializer.
example: 2x + 53 STO> y
stores "2x + 53" in a variable named "y".
To recall, just hit y and enter. In fact, if you type an equation like 3y^2 - 4y it will insert the data in for every "y" and give you:
(2x + 53)(6x + 155) as an answer.
To clear the memory:
DelVar y or F6 (2nd+F1) and clear all w/ single character names.
To recall a prevous answer, 2nd+(-) or type ans(1) for the last answer. You can also type ans(2) for the 2nd to last answer & so on.
Jan 30, 2008 | Texas Instruments TI-30 XIIS Calculator
Casio FX-115ES Scientific Calculator Logo
478 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
