Question about NAD C270 2-Channel Amplifier
Only one channel is working - NAD C270 2-Channel Amplifier
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
Sub woofer not working hear connection. but no sound switch connection and works. is S.W channel bad. How do i tell? All other channel are working.
you have tried the SW on other channels and it worked right? Have you tried other speakers on the SW channel? I think it is more likely that your SW channel's volume is too low or it is turned off in the options somewhere.
Nov 03, 2013 | Coby DVD938 Theater System
The sound works on video channel, but not on TV channels. I have no remote controller
It's not going to be the mute feature as the sound works on video. Tuner may be damaged? Could be the channel?
Dec 29, 2012 | Televison & Video
Some channels are not working, says scrambled or bad channel
hi pinkzz you must delete the channels that are bad/scrambled before you rescan because the box allready sees that the channel allready exists
Apr 21, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Channel 2 doesnt work. Channel 1 works perfectly fine and i have been using the mixer for abt a yr and from one day to another channel 2 stopped working.
did u find any solution with the mixer? I have a similar problem. Channel 2 works great, Channel 1 is sending only the Left side, something like Mono instead of Stereo.
Feb 21, 2010 | Nu Mark Numark Dxm01 DJ Mixer With Two USB...
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
Cable channels not working
auto search channels on menu. start at 1
Jan 04, 2008 | JVC AV-27D305 27" TV
NAD C270 2-Channel Amplifier Logo
130 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
