Question about Kenmore Elite 45986 Front Load Washer
HE2t front loader displays f 21 error
As the machine enters the spin cycle this error occurs and we have not been able to open the door
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Whirlpool Front Loader WFS1071BW, rinse cycle problem
I had exactly the same problem with the same machine... I've seen a few people on various forums with the same problem. The problem on mine turned out to be just the EMI filter located next to the power cord inlet. I just bypassed it for now until I can get a replacement.
Apr 26, 2013 | Washing Machines
I have a Kenmore HE2t front loader washing machine and getting a F 31 error and the door is locked with a load in machine
Hello & Welcome to FixYa
Error F31 in your washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore HE2 Plus Front Load Washer
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
My front loader is not working whirlpool
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
