Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman lt1000 with manual transmission, transmission stuck in reverse. Can move shift lever to other gears and can see it is shifting at the transmission but it stays in reverse.
  • Anonymous Mar 31, 2014
    tansmision won't shift into gear
  • 86 Answers
The detent Shaft inside transmission lost its ball and spring if its working outside transmission,could be other damage .
Posted on May 09, 2009
  • Jerry Cramer May 09, 2009
    detent ball and spring inside transmission is messed up and possible other things
  • Tony May 17, 2013
    What do u need to do to fix that
My T45 transmission is stuck in first gear and bogs down when I shift it to reverse
It appears this is a 5 speed manual transmission. There may be shift linkage problems between the shift lever and transmission. also bushings. I strongly recommend a repair manual specificly for this transmission. possibly filespeep.com or manualslib.com
How is the clutch and throwout bearing?
Mar 22, 2015 | Cars & Trucks
1991 Ford F150 won't shift into park or reverse. Will go into neutral and drive, and the linkage at the transmission moves ok
The linkage may be out of adjustment preventing the shifter from moving into reverse or park.
One way to test this is to disconnect the linkage and manually move the lever on the transmision making sure that it can be set into park. Also try moving the lever counting each click from park to low gear to make sure it is clicking into each gear. If this works then the linkage is probably out of adjustment.
On the link cable there is typically a bolt in an oval shaped metal near the transmission shift lever.
1)Detach the shift cable from the transmission shift lever
2)Put the transmision shift lever in the park position, and also the shifter in the cab
3)Loosen the adjustment bolt
4)Reattach the cable to the lever
5)Tighten the adjustment bolt in place
6)Confirm that you can shift through all of the gears
Hope this helps
Dec 01, 2013 | 1993 Ford F150 SuperCab
2008 honda sticks in park
It can be issue with gears or problem with transmission and needs to be rebuilt. Also get the ****** fluid checked. If it's low, then such problems occurs.
To troubleshoot these types of issues, check the actual solved problems with these types of issues.
There are solved help links provided below: -------
Click the link below and go through the details and diagrams to troubleshoot the problem: -----
2003 Lexus RX300: Transmission Fluid Burnt Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse, acts like it's in neutral? http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift To Reverse? http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission, with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode Fuse number 27 blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These will help.
Thanks.
The shifter needs to be inspected. If The shifter assembly is got misaligned, it has to be open and realign.
There are many other possibilities.
Also i suggest you to refer these gear shift issues, which are mostly noticed. These are direct links with appropriate solutions to the specific problems of gear ****.
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html --------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html ---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html --------- Car will not move when in gear? http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ---------- Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
------- 2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html -------- 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html -------- Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html --------- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
----------- Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
-------- Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
------------ No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html ------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html --------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html -------- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
---------- 1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html ------ Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
-------- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
-------- Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
---------- 2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html ---------- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
-------- Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html --------- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------------ 2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Nov 26, 2012 | 2008 Honda Accord
I've got a 1994 GMC Sierra 1500 5.7L V8 4x4 with automatic transmission. I have replaced the transmission filter, fluid and the shift valves. Truck still doesn't want to change gears correctly. It go
GEAR SHIFT ISSUES
Thanks.
Nov 26, 2012 | Cars & Trucks
Shift and shift button stuck in park
GEAR SHIFT ISSUES
These will help.
Thanks.
Nov 23, 2012 | 2002 Pontiac Aztek
Needing to troubleshoot transmission problems for my 2001 pontiac grand prix
It can be issue with transmission,most probably it needs to be rebuilt.
GEAR SHIFT ISSUES
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Gear shift lever is loose and mower will not move. this is on a craftsman lt1000.
Trace back the linkage from the shift lever to the transaxle to see if the linkage has come apart. If it is a manual, then I know the linkage connects to the transaxle on the top, forward, left of center. There is a retaining bolt (i think bolt, been a long time) that attaches the linkage to the transaxle. If this has backed out very much the linkage is not going to shift gears on the transaxle.
I hope this helps.
Jul 28, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Craftsman Garden
I have a 97 f-250 7.3 with a manual trans. and it wants to jump out of reverse if I dont go to 1st gear and then to rev. first.
Sounds like the shift lever is not coming completely out of 2nd gear. So, by shifting into 1st gear, you recenter the shift lever. You can confirm this by going under the truck and moving the 1st - 2nd lever on the side of the transmission with your hand. If the shifter goes into reverse after you manually recenter the 1-2 lever, then you need to correct the problem that prevents the "normal" recentering of the 1-2 shift lever.
Possibilities are: Bent shift rod; worn shifter; worn shift rod at connection to shift lever on transmission.
Oct 10, 2009 | Ford F-250 Cars & Trucks
96 escort manual 5 speed stuck in reverse
Is the stick moving? or is it 'stuck' in the reverse position as well? There are adjustments but it seems more likely that your 'stick' has come unstuck from the gear levers that actually put the gears in the right spot. Have someone look at the transmission while you move the stick to see if the levers are moving and put your response here.
May 08, 2009 | 1996 Ford Escort 4 Door
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,376 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
