Question about Dryers
How do I replace the belt on a White Westinghouse dryer
Model #DE650EDW1.
  • Dryers Master
  • 1,078 Answers
Unplug unit.
Use putty knife and unfasten the clips that hold the top down. Usually located where the top meets the body of the unit.
Top will lift up and hinge back.
Take back inspection plate off. This should allow access to motor pulley and tension pulley.
Pull tension pulley back and slid old belt off.
Just do the reverse to install the new one.
Hope this gets it done for you.
Posted on May 10, 2009
Westinghouse de600a0dw2
You'll have to trouble shoot it... the belt either jumped off the motor pully or it may have broke. Either way you'll have to disconnect it and inspect it. Remember to always unplug the unit when servicing it. If the belt broke it is not hard to replace. The drums are held by gravity on rollers. Simply lift enough to get new belt pass the roller. If there are upper rollers in the way... simply remove them. Don't remove lower rollers. Lift the drum enough to install the belt and replace the upper rollers, relocate the new belt and close it up. Done.
Dec 25, 2013 | White-Westinghouse White Westinghouse...
Tip
Westinghouse Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For all Westinghouse models use this diagram:
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
After dryer is used once trying to do a second load of wash. Push the start button and dryer refuses to turn on! All it does is make a humming noise model white westinghouse DE650E
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2011 | Dryers
Drum will not turn. White Westinghouse model dg400sxw1
belt broken or fell off. check this site http://repair2000.com/wpoolbelt.htm please take a moment to rate my reply, thanks good luck
Apr 27, 2011 | Dryers
I want to replace the belt in my white-westinghouse DE/DG 650K. How do I go about that?
Normally you need to obtain access to the complete circumfarence of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Mar 10, 2011 | Dryers
White Westinghouse Dryer model DE150J. Repairman replaced belt but unplugged selector swith. Which color coded wires goes where?
Look on the switch for markings. Match them with markings on the wires. Look close.
Oct 19, 2010 | Dryers
Older model dryer--drum will no longer spin. Need
The model number you provided is for a White Westinghouse. In order the access the internal cabinet to view the drum, you will need to lift the top panel. This is accomplished by inserting a putty knife along the front seam where the top meets the front of the dryer. About 2 inches in from each side is a small retaining clip. Push in with the putty knife and the top should pop free and lift up. The belt should be visible around the drum if it still intact. If the belt is loose, or missing, it has probably broken.
NOTE: The only way a belt will come off the drum while enclosed in the cabinet is if it breaks.
CAUTION: Make sure you UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even with it turned off.
To access the drum to replace the belt, you will need to remove the front panel. Remove the lint screen and lint screen cover in the door, first. Then, remove any screws holding the panel in place. The belt can be installed with the drum in place. Simply loop it around the drum first, then feed the remaining portion of the belt behind the blower fan housing and loop it on to the drive motor pulley and belt tensioner.
The part number for a replacement belt (if required) is 134503600. You can purchase a new one at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Prices vary between these sites, so shop around for the best deal. The first three sites also offer very helpful exploded view parts diagrams you can use as reference. Repairclinic.com will have diagrams to show up how to properly route the dryer belt. Just click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram G under Westinghouse.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: If the belt isn't the problem, please let me know.
Oct 10, 2009 | Dryers
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
1,790 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
