Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax will not pic up
Hello- per the above machine i can not get the fax pick up to work, can fax out but nothing in unless it turn on then off the auto answer button, any suggestions
    Genius:
  • 1,601 Answers
Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Posted on Nov 12, 2007
SOURCE:
Hello! We just purchaesed a Brother FAX 2840. Set up was no issue at all, sending out faxes with ease. Sadly it wont receive any unless I pick up the handset and press start.
WHERE IS THE REC MODE SET, SHOULD SHOW ON THE DISPLAY, IN MENU SETTINGS, SET REC MODE TO AUTO. DO YOU HEAR A RINGTONE WHEN YOU PICK UP HANDSET. IF NOT CHECK WHERE TELEPHONE CORD IS PLUGGED IN SHOULD BE LINE, SOMETIMES PEOPLE PLUG INTO EXT PHONE...
Aug 16, 2018 | Brother Office Equipment & Supplies
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
Feb 06, 2013 | Sharp Fo-3150
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Hello! My fax will not answer on my HP OfficeJet
Please oress the button "auto awnser" on the printer which is on the left of the printer front panel under FAX. Once we press the button the libht should glow.
This will fix the issue.
May 17, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Jan 23, 2009 | Toshiba E-Studio 3511 Color Copier
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
Fax will not recieve but will send fax
what does the display reed. To receive fax automatically the display needs to reed
( fax mode or auto ) . If in the manual mode you need to pick up the receiver listen for the tones then press start.
make sure the phone cord from the wall jack is from the wall to the line connection MOT THE EXT. CONNECTION on the fax ( nothing in between the wall & fax )
hope this works
C.W.H.
Dec 12, 2008 | Brother FAX-575 Plain Paper Thermal
Panafax uf-890
The likely hood is that someone has turned off auto answer check the manual how to change this the other option if it always did auto automatically then turn the machine off at the wall socket and then turn back on this will boot back how it was. (try this first) If it doesn't work then check that the auto answer is switched on.
If none of the above work then it will be the modem that is not picking up the line and will need to be replaced.
Hope the first solution helps you
Thanks J
Jan 05, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Change dial-times before pickup
Press fuction 7/ monitor 4 times slowly/ press */ press 3. Wait for printout. Do the above only press 1 as last step, enter the number to change whatever this parameter/ press set/ stop/ stop
May 23, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
193 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
