Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Logitec Wireless keyboard and mouse
I can't get new Logitec wireless keyboard & mouse to work. I tried plugging into USB port and P/S 2 port.  Mouse works sometimes, keyboard never works. Logitec tech support says it's computer's fault. I don't see how.  Any suggestions?  Thanks
  • Anonymous Mar 28, 2014
    It there any way to get the logitach m570 to work without the original usb receiver. I do have a fully functional Logitec M85. Can I use the M85 USB and trick it into working for the m570 or have any other suggestions
    Genius:
  • 1,601 Answers
Essense702,
I presume the batteries were in correctly.
did you connect them when the computer was off, and let windows find them on bootup.
Also, make sure that you follow directions on how to get them to connect. And, make sure you run the cd that came with it.
Posted on Oct 23, 2007
  • Thomas Christopher
    Thomas Christopher Oct 31, 2007
    did this help??
    Thomas Christopher Nov 06, 2007
    Did this work?
    Please post an answer so we can help you further.
    If it worked please rate this post as solved.
    Thanks,
Do i need a keyboard and a receiver for the mouse to work and if not how do i hook it up
Your wireless mouse and Keyboard work with the same wireless transmitter that is plug in into a USB port.of your computer. You can use the wireless mouse with that USB transmitter and dont use the wireless Keyboard. If you need a keyboard you can get one to be plug in into a USB port with the wire attach to the keyboard.
Mar 23, 2012 | Micro Innovations KB982W-F Wireless...
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image 838398_receiver.jpg Collapse this imageExpand this image 838398_mouse_bottom.jpg Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Nov 21, 2010 | Computers & Internet
Wireless mouse does not work after changing batteries.it always has in the past The Dell computer and mouse is probably 8 years old but has always worked.
Try moving the mouse receivers usb plug in to another port. Unplug any new devices and restart computer. Then replug in any new usb devices.
If still not working.......
Look at Office Depot and other office stores for a replacement wireless mouse. I have seen them as low a $9.99 on up. You might even want to upgrade and get a wireless mouse and keyboard set.
Mar 08, 2010 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Optical mouse
Yes you may use your regular keyboard if it plugs into the keyboard port the the wireless mouse plug into a usb port.
Depending on how the wireless mouse/keyboard reciever plugs into your computer. it's either it splits into one keyboard plug and one mouse plug OR just on usb plug.
Mar 01, 2009 | Compaq Wireless Keyboard/Mouse p5304
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Mar 02, 2008 | Sakar 62150 Keyboard
Wireless keyboard & mouse not working
First download and run regscrub xp and ccleaner to clean up your system then try uninstalling and reinstalling the logitech setpoint software and try the keyboard and mouse again. Let me know if this works.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
May 25, 2007 | Impression Products Impression M1 Wireless...
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
234 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
