Question about Toys
Scooter won't run
My son's schwinn s500 electric scooter seems to have a battery problem. what is the expected life of a battery? I plug it in and the indicator light shows a full charge, yet we get no lights on the scooter.
  • 40 Answers
Hi, Well it sounds like you have a wire not connected or the Twist throttle part is bad. The best thing is to use Volt meter on each battery and make sure they are at 13 volts of more. If they are 11-12 volts the batteries are no good. When you turn the switch on does it make a Click sound? Take off your battery access panel it is where you put your feet. Your batteries have a red and black wire with a wiring harness attached to them. This is where you want to make sure they are plugged in. If they are Plugged in Your Scooter has to Have a Blown Fuse. Check these out and get back to me with what you find. Batteries last 1 year if you take good care of them.
Posted on May 10, 2009
How do I determine the age of a Schwinn S350 Scooter?
Get the serial number and contact the Schwinn company. They can give you the manufacture date.
Mar 07, 2016 | Max Life Battery 12V 10Ah Schwinn S350,...
Battery charging and running issue
hi, you say you replaced the batteries , but there could be other factors involved here...
Firstly don't run it with the charger plugged in , you can damage everything ...
1. the charger socket or related wiring to the batteries is either faulty or too higher a resistance...
Regards
Rob
www.facebook.com/gewizrepairs
Aug 11, 2015 | Health & Beauty
I have a Schwinn S500 electric scooter.When you turn the power switch on the scooter will not run. the power indicator by the throttle jumps from low to medium charge. I charged the battery for the 8 hrs...
Hi Ron, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
Sep 28, 2011 | Transport Schwinn Rechargeable Portable ...
I'm trying to figure out what kind of battery a schwinn electric scooter takes it is a s-180
Your scooter uses dual 12-volt, 10-amp hour sealed recyclable lead acid battery.
You may want to open below link to see some examples of batteries suitable to your scooter.
http://www.batteriesplus.com/products/78-0/6069-Electric-Bike-Scooter-Battery/252604-Schwinn/S180-Electric-Scooter/1.aspx
Regards,
Jeep Brainy
Sep 11, 2009 | Transport Schwinn Rechargeable Portable ...
Battery doesn't charge
i had the same problem so i took the battery out and pluged the moped in and it ran so i knew the battery had a prob then i took the battery out of the canvas case and it had expanded to the point were it almost leaked (exploded battery in other words)
Jul 16, 2009 | Transport Schwinn Rechargeable Portable ...
What kind of battery do i need for my scwinn s500
Do you know the model number on the battery that you have? This website should be able to get you started if you don't. Check out http://www.batteryinternational.com/electric-scooter-batteries-schwinn.html
Jul 06, 2009 | Transport Schwinn Rechargeable Portable ...
Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Mar 03, 2009 | TitanNet PowerStar Replacement Battery for...
I have an S500 schwinn electrodrive scooter, what kind of battery
call up currie tech there will be a number on your product you will have to order the parts
Jan 15, 2009 | Transport Schwinn Rechargeable Portable ...
Toys Logo
390 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
