Question about HP PSC 1510 All-In-One InkJet Printer
Stuck Scrunched up Paper! HELP!
I was printing off something and when i put the paper in and pressed print as usual suddenly 3/4 of the paper went in and scrunched up and got stuck. I've opened the flap at the front with the ink cartridges but it's stuck there good. Some ripped off as i tried to pull it out. Please help urgently i really need that document.
    Sergeant:
  • 296 Answers
Hi
plz chek these sites,i blliv u will b helpfull.
http://www.ehow.com/how_113761_clear-printer-paper.html
http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
don forget to rate this answer if u r satisfied wth it
thankyou nd best of luck.
Posted on May 09, 2009
Every time I try to print a paper, it always says that it has a paper jam. I have took out the paper, and did everything it said to do, but it still jams. What should I do?
Usually if it says a paper is jammed, there "is" something in there that got missed. You just have to keep digging until you find it. You did't say if it actually starts to print first, or if it says it right off the bat from the previous print attempt. It may require further disassembly to find the problem, ...it could be something very tiny if a piece tore off when you were unjamming it before. It could also be "mis-feeding" ...reply with a liitle more info if you don't find it.
Jun 12, 2010 | Dell 926 All-In-One InkJet Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
When I turn on my Epson DX8400 it says that I have a paper jam that I can't find. The print head cartridge container goes across to the left in its usual warm up sequence, then make this awful noise and...
take a look at the back of your printer there should be a panell that comes off if you can take that pannel off look in there there is most likely paper stuck back there not allowing your printer to spool
Dec 09, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Paper jams sideways and gets munched up - will not print
Check the paper path way , and also leds that directing paper.
hope that help you
thanks
Hamedo
Oct 25, 2008 | Dell 922 All-In-One InkJet Printer
Dell AI0 926 All in One shows Clear Paper Jam with no paper in it.
I put my hand inside and found something clicked just below the right of the first two rollers. THen it worked i think whatever clicked must have gotten stuck but i dont know why
Oct 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Only print the printed paper.
IF YOU TAKE OUT THE TONER AND TURN IT SO THAT YOU CAN SEE THE DRUM (GREEN ROLLER) YOU WILL SEE AN ASSEMBLY SCREW ON THE RIGHT HAND SIDE. YOU WILL SEE THAT IT LOOKS LIKE A PIECE OF PLASTIC WERE BROKEN OF. MELT A LITTLE PIECE OF PLASTIC ON THERE TO EXTEND IT WITH ABOUT 5MM. IT IS USED TO PRESS A SWITCH INSIDE THE PRINTER. IF THAT SWITCH IS NOT PRESSED THE PAPER ONLY FEEDS UP TO THE DRUM.
Sep 01, 2008 | Samsung ML 2010 Laser Printer
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Paper jam 580
You know what I would try, look in the fuser unit and see if any paper ripped off and got stuck in there. Wait until it's cooled down, but usually if you have to pull paper of of there, little pieces can get caught in there. Also, you may have a full sheet in there, I've had people leave and entire sheet in the fuser all scrunched up and the machine print fine for another 100 prints and then have an error and the paper coming out looking like it almost caught fire.
That's where I would look first if there isn't anything in the print path under the toners, etc.
Oct 27, 2007 | OKI C5100n Laser Printer
HP PSC 1510 All-In-One InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
