Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Where can I download a free wiring diagram for a 1995 Murray lawn tractor?
  • twhite592 May 24, 2009
    Need a wirering diagram for a 1980 mtd ride on mower 12.5 hp B@S
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 59 Answers
SOURCE: wiring diagram murray lawn mower model 289707
is this the model number off the engine or the chassie? Will need the number off the chassie, usually under the seat.
Posted on Sep 24, 2010
SOURCE: every time I am running my murray lawn tractor i
have a 13.5 hp tecumseh ohv formula riding mower. when engage blade for cutting white smoke comes out of front of engine. is the motor blown? can it be fixed or cheaper to replace?
Posted on Jul 27, 2011
Belt drive diagram for a murray lawn mower model number 42598x92
Visit the Murray website at http://www.murray.com
They have downloadable manuals and diagrams there.
May 14, 2015 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I nned a wiring diagram for a murray lawn tractor
My search engine, Bing, came up with a great diagram when "Murray lawn tractor solenoid" was put in the images section. It shows clearly which wire goes where on a generic system.
Aug 15, 2014 | Garden
How to install drive belt murray lawn mower
You can go to www.murray.com , enter your model number and download an owners manual which will have the instructions and diagram on how to do it
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to find out how to wire starting system
1308d8d.jpg here is a typical starter/solenoid wiring diagram used on all ford lawn tractors and 99 percent of craftsman/ayp mowers hope this helps........
Jun 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
1,012 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
Dan Webster
Dan Webster
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
