Question about Friedrich M18CE Air Conditioner
Friedrich Mini-Split blowing fuse
I have a Friedrich Mini-Split AC unit that keeps blowing the 10 amp time delay fuse.  After replacing the fuse the unit will run for 20 to 30 minutes and then blows the fuse again. Any ideas?
  • Anonymous Mar 18, 2014
    ygmi unit
  • Anonymous Mar 31, 2014
    Each time I turn on my split unit, it will work for about five minutes and blew the little 5amp fuse at the circuit board of the indoor unit. I have replaced fuse twice.Please advice.
    Problem Solver:
  • 7 Answers
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Posted on Oct 16, 2007
Remote codes for Friedrich split ac
You need a replacement remote for that unit. The codes are dedicated and not like television codes. You can't use a Universal Remote, especially as the functions of the split AC aren't on the remote.
Google
make model replacement remote
or contact the maker.
https://www.electronicadventure.us/friedrich.htm
Amazon com Replacement Friedrich Air Conditioner Remote Control...
Contact Us
https://www.remotes.com/friedrich-remote-controls-s/2027.htm
Jul 23, 2018 | Heating & Cooling
I have a Eaton-Cuttler-Hammer 60 Amp fusible Pullout Disconnect for my house AC unit. When the weather gets warm and the AC runs alot, one, or both, of the fuses blows. The plastic panal inside the metal...
Does not matter which way the fuses go....
The contacts are bad and will cause the fuses to blow sooner because they are heating up...
It will not cause a fire, but you should have the disconnect replaced or you will have continuous problems...
heatman101
Jul 10, 2011 | Heating & Cooling
Fuses on AC unit keeps blowing need solution can't continue to b replacing fuses
are the fuses time delay if they are not then get them ..try cleaning the coil on the roof with a garden hose .if the coil is dirty the unit uses more amps to run causing fuses to blow /or you may need a new start capacitor for the compressor /fan its the round silver thing with wires connected to it .when you take it apart to clean ..good luck let me know../joe/
Aug 26, 2010 | Dometic Rooftop RV Air Conditioner
The inside unit on my Bryant is working. The fan is on. However the outside unit is not running. I changed fuses and it worked for approxmately 20 minutes then stopped again. Any suggestions?
I would think that when you changed the fuses you 'cured' the problem - which was a blown fuse(s) - but now you have the same problem again - a bad fuse(s).
To test this - you could replace the fuses again - but first - I would make sure that the fuses you are using are 'time-delay' fuses. It should say on the fuse itself 'time-delay' or 'dual-delay' or something like that.
If you're using fuses that are not 'time-delay' your problem could be solved as easy as buying some 'time-delay' fuses.
However, -- fuses blowing -- are usually caused by electrical motors - i.e. compressor/fan motors - breaking down 'electrically' - and heating up and causing the amp draw to increase past the point of the fuses, i.e. a 40 amp fuse will blow when the AC starts to exceeds that rating.
One "longshot possibility" - is - if the condenser is 'really dirty' - it will cause the compressor to run hot and possibly cause the fuses to blow. I would make sure 'all power' including the inside thermostat is "off" - and then 'wash out' the condenser (the coil in the outside unit) real good with a water hose.
Of course another possibility is that you have a loose electrical connection(s) somewhere in the AC. If you're inclined to - you can again - make sure all power is off - and poke around in your AC looking for loose wire connections. Just be sure 'all power' is off before you do this.
If you are using 'time-delay' fuses and your condenser is 'clean' and you can't find any 'loose connections' - and you continue to have the same problem (blowing fuses) - I would suggest calling a Service Tech.
Note: never replace a fuse with a bigger fuse, i.e. if the fuses in your unit are 40 amp - 'do not' put in 50 amps.
It is possible that the fuse(s) you are using are not the 'right size' but that would have to be determined by a Service Tech and actually - is not a strong possibility, although certaintly possible.
hope this helps
Aug 14, 2010 | Bryant Heating & Cooling
Energy Knight AC Blowing Fuses
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
May 28, 2009 | Comfort-Aire HMC24AD-1 Air Conditioner
Weather King split AC system.
Turn the power off ,and check all the electrical connections for loose connection or wires. also make sure these are slow blown timmed delayed and not one-time fuses. Thank-you verymuch!
Aug 30, 2008 | Weather King 10AJA2501AH Air Conditioner
I have a problem with my alero.the mini fuses (10 AMP)that go to the gauges,ac,and speedometer,get blown out every tine i install a new one in place.the ac blower comes on but no ac cold air.both the mini...
Without being there to help your best bet would be to get a box of fuses and start unplugging each component one at a time until the fuse does not blow. Now you will know where the problem is.
Aug 11, 2008 | Oldsmobile Alero Cars & Trucks
Friedrich QuietMaster SS12H10
It is probably either the Compressor and or the capacitor that has failed. The compressor will hum and pull a lot of amps when it has seized up. Sounds like it is time for a new unit.
Jun 30, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Friedrich M18CE Air Conditioner Logo
532 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
