Zanussi ZWF1221W will not spin
We have a two and a half year old Zanussi ZWF 1221W washing machine that is no longer spinning. Checked the filter in the bottom at the front and the waste pipe and both are clear. It will fill with water but not spin. It is taking the washing powder but not the conditioner. Checked the belt and it is fine and I can spin the drum by hand easily enough. It will also drain the water using the pump too. Is it the motor that is gone?
5 Suggested Answers
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
beltronic205
  • 1461 Answers
SOURCE: my machine won't take the fabric conditioner. It
ok try removing the soap tray and cleaning. it works by filling to a certain level then allows to empty by way of Syphon effect, you can check this easy with a glass of water fill it as far can go does it drain away? It should , if it does then try with softner on wash should now be ok, providing The valve coils are okay..you can let me know.
Posted on Jun 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
barkencoa
  • 3463 Answers
SOURCE: zanussi zwf 1221w drum bearing replacement, is
This is not an easy repair to carry out, it involves a complete strip down of washer, and removing the whole drum assy from the washer, and until it is stipped down, you will not know if the drum shaft is worn, if it is, then this puts it way beyond an economical repair.
Posted on Feb 02, 2011
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
60 degree wash wont spin
Would it not take time to heat up water to 60 degree temp before it starts to spin ?
May 03, 2014 | Zanussi Washing Machines
My zanussi zwf1221w won't stop spinning. Any ideas
Check for a blocked filter. Or it could be your pump thats failed.
Mar 30, 2012 | Zanussi Washing Machines
Zanussi zwf 1221w drum bearing replacement, is this an easy job to do
Feb 02, 2011 | Zanussi FLA1001W Front Load Washer
Zanssi washing machine ZWF 1221 W will not spin
Do you realise there is a law I understand that says for 6 yrs the goods should be fit for the purpose you bought them for. Look at this "your rights " & go tackle the store you bought the machine from.
http://www.guardian.co.uk/money/2006/jun/01/yourrights.legal4
Jun 21, 2008 | Zanussi ZWF1430W Front Load Washer
Got a 4 year old zanussi washing machine and its developed a fault where when it gets to the spin part of the program it just sits there and does nothing,read the manual about unbalanced loading but even...
check wether it does the same thing unloaded if not then its likely to be carbon brushes ,,, presuming it is tumbling durin the wash/ rinse cycles also check front filter zanussi wms will not spin if they cannot clear all water in the drum
Jun 19, 2008 | Washing Machines
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
