Question about Microsoft Office Xp Professional Full Version With Adobe Acrobat 5.0 (269-04508 BUNDLE) for PC
Setting up SMTP mail service for Yahoo Small Biz Account
I am using Outlook 2007 for client email service and my incoming mail is working ok from my ISP's webmail service.
I am however having problem with outgoing email service.  I have set up the smtp service as "smtp.bizmail.yahoo.com".  For the username and password, I have used the Yahoo login details.
What am I doing wrong that I cannot send outbound messages?
Regards
Gafvi
  • 78 Answers
Open outlook 2007 go to Tools / account settings
highlight your account and select change. this will take you to change email account. at the bottom if you have if you have Require logon using secure password authenication check uncheck it and then click on MORE SETTINGS / select outgoing server. make sure you have My outgoing server (SMTP) requires authentication is checked. and select use same setting as my incoming server. then click the advanced tab and check This server requires an encrypted connection (SSL) this should change the incoming port to 995, last change the outgoing port to 465 and click ok.
Posted on Oct 11, 2007
SOURCE:
Can I configure microsoft outlook 2007 to work with my yahoo e-mail if i'm connection through clearwire at home and I'm not on a network
If you are not connected to the internet, you can only work offline, and for example, if you write an email it will not send until you do connect to the internet.
You can configure Outlook 2007 to work with Yahoo.
If you want to "POP" your Yahoo! Mail into your Outlook 2007 application, here's how:
  1. From the Tools menu, select "Account Settings." If you do not see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the Email tab, click New.
  3. Check the box next to the first option, "Microsoft Exchange, POP3, IMAP, or HTTP" and click Next.
  4. In the Your Name box, type your name as you'd like it to appear when you send a message.
  5. In the Email Address box, enter your Yahoo! Mail address (for example, "[email protected]").
  6. Check the box for "Manually configure server settings or additional server types" and click Next.
  7. Check the box next to the first option "Internet E-mail" and click Next.
  8. In the Server Information area, under "Account Type" select POP 3 from the pull-down menu.
  9. In the Incoming mail server field, enter: pop.mail.yahoo.com.sg
  10. In the Outgoing mail server (SMTP) field, enter: smtp.mail.yahoo.com.sg
  11. In the Login Information area, in the User Name field, enter your Yahoo! ID (your email address without the "@yahoo.com").
  12. In the Password box, enter your Yahoo! Mail password.
  13. Check "Remember Password" if you don't want Outlook to prompt you for your password each time you check your mail. Handy!
  14. Do not check the box labeled "Log on using Secure Password Authentication (SPA)."
  15. Click on the More Settings button.
  16. Click on the Outgoing Server tab and check the box next to "My outgoing server (SMTP) requires authentication."
  17. Click on the Advanced tab.
  18. Under "Incoming Server (POP3)", check the box next to "This server requires an encrypted connection (SSL)". The port number in the "Incoming Server (POP3)" field should automatically change from 110 to 995. If it doesn't, make sure the port number is set to 995.
  19. Under "Outgoing Server (SMTP)", check the box next to "This server requires an encrypted connection (SSL)". Enter port number "465" in the "Outgoing Server (SMTP)" field.
  20. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, don't check the box.
  21. Click the OK button.
  22. Click the Next button on the Email Account Wizard, then click Finished.
  23. Would you like your Yahoo! Mail inbox to be your primary inbox in Outlook 7? If so, click the Tools menu and select "Account Settings." If you don't see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  24. From the list, select the pop.yahoo account you've just added and click the Set as Default button.
  25. Click the Close button. You're done!
Troubleshooting instructions
If you followed the above configuration steps, you should be all set. However, if you cannot send or receive mail with your email client, try the following tips.
The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on, follow these steps:
  1. From the Tools menu, choose "Account Settings."
  2. Select the "E-mail" tab.
  3. Select your Yahoo! Mail account and click Change.
  4. Click on the "Outgoing Server" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Please make sure that "Log on using" is not checked.
  7. Click OK.
To control deletion of messages from the Yahoo! Mail server:
  2. Click on the "Email" tab.
  4. Click on the "Advanced" tab.
  5. Check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Please note that setting your email client to remove messages from the server will cause your messages to be deleted from the server. Once the messages are deleted, we are unable to retrieve them.
  6. Click OK.
  7. Close Microsoft Outlook and restart.
We strongly recommend that you enable SSL for both POP and SMTP, as detailed in the above instructions. This will ensure that your Yahoo! ID, password and email messages are transmitted securely between your mail client and the Yahoo! servers. However, if you choose to not use SSL for SMTP, your email client will likely default the SMTP port to 25. If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
  1. From the "Tools" menu, select "Account Settings"
  2. Select your Yahoo! POP account and click on Change.
  3. Click on the "Advanced" tab.
  4. Click OK and Close.
May 05, 2011 | Microsoft Office Computers & Internet
How to configure yahoomail in message menu in samsung b7722
Follow the below mentioned steps : 1. Locate information concerning your particular email service's incoming POP3/IMAP and outgoing SMTP server addresses. Refer to the resources section below for a list of server settings that pertains to many common e-mail providers.nformation mentioned below :
Yahoo Mail offers standard POP3 access for receiving emails incoming through your Yahoo mailbox, by using your favorite email client software. To setup your email client for working with your Yahoo account, you need to select the POP3 protocol and use the following mail server settings: Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (SSL enabled, port 465) Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (SSL enabled, port 995) POP Yahoo! Mail Plus email server settings Yahoo Plus Incoming Mail Server (POP3) - plus.pop.mail.yahoo.com (SSL enabled, port 995) Yahoo Plus Outgoing Mail Server (SMTP) - plus.smtp.mail.yahoo.com (SSL enabled, port 465, use authentication)
IMPORTANT : Yahoo mail on outlook or cell phone is a paid service by yahoo.
2. Turn on your mobile phone and wait for the standby screen to appear. go to "Menu" button on your screen and select "Messages" from the menu, press "Select" to continue. 3. Go to the "Settings" menu and press "Select," choose the "Email" option. Select the "Email setup wizard," press the "Select" button and hit "Yes" to continue.
4. Choose an email account type you wish to configure, press "Next," choose the "Account" option, press "Name" and use your keypad to label your new email account.
5. Press the "Next" button to continue with the email setup. Enter your email address and password, press "OK" to continue.
6. Enter the incoming POP3/IMAP information pertaining to your particular email service and press "OK" to continue. Select the "Outgoing Server (SMTP" menu item) and enter in the appropriate SMTP address for your email provider and press "OK" to continue. 7. Hit the "Select" and wait for the "You have configured this email account successfully" dialog to appear.
May 01, 2011 | Cell Phones
Trying To set up yahoo mail in my HTC phone need details
You will need adjust the mail application's POP settings to get your Yahoo! Mail messages into it.
POP access is a service for owners of one of the following:
Yahoo! Mail Pop Access & Forwarding
Yahoo! Mail
Plus Premium Services
A Broadband account
A Small Business account
Please note that access to IMAP servers is not available.
To use an email client or application to send and receive Yahoo! Mail messages, you may need to designate a new incoming (POP) mail server and a new outgoing (SMTP) mail server. Consult your owner's manual for instructions on designating servers in the email application.
If you can't add new POP or
SMTP servers, you will need to change your current server settings.
Before you make any changes, write down your current settings. You might need to revert to your original settings later if you decide to send and receive messages from your other email addresses.
The following steps will help you find the POP settings for your Yahoo! Mail account and configure it:
Log onto your Yahoo! Mail account from a PC.
Click Options > Mail Options.
Click POP & Forwarding.
Click Set up or edit POP & Forwarding.
Click POP Settings.
Note your Server Setting information. Your phone email client or application will ask for these settings:
Incoming Mail Server (POP3)- for example, pop.mail.yahoo.com.
Outgoing Mail Server (SMTP)- for example, smtp.mail.yahoo.com.
Account Name/Username, your Yahoo! Member ID- for example, myuserID.
Email address, your Yahoo! Mail address- for example, [email protected]
Password, your Yahoo! Mail password- for example, l0ngitudin*l
Notes:
POP server settings may change from time to time and you should confirm the current POP server settings in Yahoo! Mail if it is not working.
When using
Microsoft Outlook, replace the "@" in your address with "%".
As an alternative to configuring Yahoo! Mail POP mail configurations, go to:
http://mobile.yahoo.com/mail
http://help.yahoo.com/l/us/yahoo/mobile/...
Enter your phone number and send a link to your phone; the best Yahoo! Mail experience will be suggested to you.
Have a nice day
Jan 01, 2011 | Yahoo Mail
How to receive mails from two yahoo accounts to one place?
Hi Vinay,
You need to configur your microsoft outlook or windows mail or outlook express in such a way that you recive mails from both the account to one inbox. Follow the below steps if you have ms outlook.
Microsoft Outlook Express
Yahoo! Mail users can read their email in Outlook Express by subscribing to the Yahoo! Mail Plus service. This service allows you to use Outlook Express or another POP3 client to access and manage your Yahoo! Mail messages.
Outlook Express allows you to add a new email account to your existing profile. This means you do not have to replace your current settings in order to send and receive Yahoo! Mail messages. Here's how:
1. From the Tools menu, choose "Accounts."
2. Select the "Mail" tab.
3. Click the "Add" button.
4. From the Add menu, click "Mail."
5. In the text box labeled Display Name, type your name and click "Next."
6. In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next."
7. Under "My incoming mail server is a..." select "POP3."
8. Type "pop.mail.yahoo.com" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
9. Type "smtp.mail.yahoo.com" in the Outgoing Mail (SMTP) Server box.
10. Click "Next."
11. In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com").
12. In the Password box, type your Yahoo! Mail password.
13. If you want Outlook Express to remember your password, check the "Remember password" box.
14. Do not check the boxes labeled "Log on using Secure..."
15. Click "Next."
16. Click "Finish."
Important: The Yahoo! Mail SMTP server now requires authentication. To turn this setting on:
3. Double-click the account labeled "pop.mail.yahoo.com."
4. Select the "Servers" tab.
6. Click "OK."
To control deletion of messages from the Yahoo! Mail Server:
4. Select the "Advanced" tab.
5. In the Delivery section at the bottom of the window, check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Do not check this box if you want your messages to be deleted from the Yahoo! Mail server once you have received them in Outlook Express.
1. From the "Tools" menu, select "Accounts"
2. Select your Yahoo! POP account and click on the "Properties" button
4. Next to "Outgoing server (SMTP), change port 25 to 587
5. Click "Apply", then click "OK" and "Close"
Dec 20, 2010 | Yahoo Mail
I have 160 mails unread and i am not able to read those mails, plz help me put
setup your yahoo mail on any email client(outlook express,ms outlook etc) and download the emails
with the below settings
    Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)
    Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
Apr 26, 2010 | Yahoo Mail
I am having problems setting up outlook 2007 for my yahoo.es address.what are the incoming and outgoing mail settings. when I try to do the auto set up it doesnt seem to recognise my network password for...
Here’s how you can read your Yahoo! Mail Plus email using Outlook 2007:
  1. From the Tools menu, select Account Settings.
    Note: If you do not see Account Settings, place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the E-mail tab, click New. The Add New E-mail Account dialog box appears.
  3. Select the Manually configure server settings or additional server types checkbox. Click Next. The Choose E-mail Service screen appears.
  4. Select Internet E-mail, and click Next. The Internet E-Mail Settings screen appears.
  5. Complete the fields as follows:
    • Your Name: Type your name as you’d like it to appear when you send an email message.
      E-Mail Address: Type your Yahoo! Mail Plus email address (for example, [email protected]).
      Account Type: Select POP3 from the pull-down menu.
      Incoming mail server: Type plus.pop.mail.yahoo.com.
      Outgoing mail server (SMTP): Type smtp.mail.yahoo.com.
    • Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
  6. Click More Settings. The Internet E-mail Settings dialog box appears.
  7. Select the Outgoing Server tab:
    • Select the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  8. Click the Advanced tab:
    • For Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field automatically changes from 110 to 995. If it doesn’t, type 995.
    • In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
    • Next to Use the following type of encrypted connection, select SSL from the pull-down menu.
    • If want to keep a copy of your email messages on the Yahoo! Mail server, select the Leave a copy of messages on the server checkbox. If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, leave the box unchecked.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server after Outlook has downloaded them onto your computer, leave the box unchecked.
      Note: After your messages are deleted from the server, we cannot retrieve them.
  9. Click OK to close the Internet E-mail Settings dialog box.
  10. Click Next to continue. The Congratulations screen appears.
  11. Click Finish to close the Add New E-mail Account dialog box.
  12. Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can’t send Yahoo! Mail from Outlook 2007, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!’s SMTP server. To make this change:
  1. From the Tools menu, select Account Settings. The Account Settings dialog box appears.
  2. Double-click your Yahoo! Mail Plus account. The Change E-mail Account dialog box appears.
  3. Click More Settings. The Internet E-mail Settings dialog box appears.
  4. Click the Advanced tab.
  5. In the Outgoing Server (SMTP) box, type 587.
  6. Click OK to close the Internet E-mail Settings dialog box.
  7. Click Next to continue. The Congratulations screen appears.
  8. Click Finish to close the Change E-mail Account dialog box.
  9. Click Close to close the Account Settings dialog box.
Feb 11, 2010 | Yahoo Mail
When I tried to send email from Outlook, the Internet Service Provider replied -ERR [AUTH] invalid user/password. How can I correct this error?? My ISP is att.net. I have not found a solution on that...
This means that your user/password combination is wrong for that email server. So double check that you have the right password and user name entered for that account in Outlook. If you're 100% sure you have it right, then you might be using the wrong email/authentication server. If you continue to have problems and are located near Washington DC, feel free to contact me through my website.
Nov 03, 2009 | Yahoo Mail
What incoming and outgoing mail server info. do I need to set up
Hi, For yahoo mail you need upgrade to yahoo mail plus (@ $19.99 per year) to get the full pop3 service for access to Outlook,Incredimail, Thunderbird and others.
For more info on setting up your pop3 account see the links below.
http://help.yahoo.com/l/us/yahoo/mail/cl...
* Incoming Mail Server (POP3): plus.pop.mail.yahoo.com
Use SSL, port: 995
* Outgoing Mail Server (SMTP): plus.smtp.mail.yahoo.com
Use SSL, port: 465, use authentication.
If you have “yahoo.co.uk” address some users can get free pop forwarding see below.
Click “options” (top right) on your mail page>mail options>pop and forwarding>
Set up or edit pop & forwarding>type in the address you want to forward to and
click save.
* Incoming mail server (POP3): pop.mail.yahoo.co.uk
Use SSL, port: 995
* Outgoing mail server (SMTP): smpt.mail.yahoo.co.uk
Use SSL, port: 465.
Note: In order to be able to send emails from outlook and others through/to yahoo (pop3) you need to pay for a yahoo mail plus account.
http://help.yahoo.com/l/uk/yahoo/mail/cl...
Apr 10, 2009 | Yahoo Mail
Incoming and outgoing identity
# Yahoo! Mail Settings
Unlike Hotmail, Yahoo! Mail offers standard POP3 access for receiving emails incoming through your Yahoo mailbox, by using your favorite email client software. To setup your email client for working with your Yahoo account, you need to select the POP3 protocol and use the following mail server settings:
Nov 03, 2008 | Yahoo Mail
Open Questions:
SBCGloBaL EmAiL HeLpliNe PHoNe 1^855+536+5666NuMbER ^%% CUSTOMER HELP It doesn't matters that which kind of problem faced through the users,the support 1*855*536*5666 team that has been appointed for Sbcglobal is quite intelligent and impressive in solving the technical difficulties belongs to different categories.For contacting the technical team users needs to do the instant connectivity over the help number 1*855*536*5666 that has been given on the website.First the users would be accessed through the experts by the help of the remote access technique that is quite convenient for the detection of the respective issue.The technique that would be used to solve the technical problem depends upon the criticality of the problem.One user can have more than one email account. May be user wants to close any one and thus want to have all the contacts in another existing account. It is not difficult to have the contacts transfer from one account to another 1*855*536*5666 one. Sbcglobal email users can call our anytime to get connected with one of our highly trained technicians who are available round the clock to offer most smart solutions to any issues. Not just this, our team of technical support 1*855*536*5666 also offers 100% reliable technical resolutions through SBC yahoo DSL support number and . Our email specialists have been highly trained and are totally adept in offering the best solutions for just about any SBC customer care related tech support issue that you may be facing. This is called as Import/ Export.
Oct 19, 2019 | Yahoo Computers & Internet
AOL MAil CuStOMeR {1-855*536*5666}#[email protected] Service OHIO This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 19, 2019 | AOL Computers & Internet
See all Microsoft Office Xp Professional Full Version With Questions
Microsoft Office Xp Professional Full Version With Adobe Acrobat 5.0 (269-04508 BUNDLE) for PC Logo
550 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
