Question about Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to...
My i450's light is flashing green/red and will not print. I have had this problem before and rectified it by manually turning the paper delivery wheel. I have tried this several times but I'm still ge
SOURCE: Flashing Green & red light
great job guys. just about threw my printer out, looked in the toner and behold! funny thing, i would have saved the toner for the numerous other HL-1440's around.
Posted on May 22, 2008
frcs68
  • 1605 Answers
SOURCE: lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Posted on Apr 17, 2009
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
  • 51 Answers
SOURCE: Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Posted on Sep 26, 2009
huntwolfe
  • 20 Answers
SOURCE: "Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Posted on Oct 02, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
on Jun 11, 2011 | HEWLETT-PACKARD Hewlett Packard P1102...
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Sep 25, 2009 | Epson Stylus Photo R200 InkJet Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
160 people viewed this question
old marine
old marine
