Question about Olympus FE-230 Digital Camera
When camera card is displaying full, how to I access pics to delete and make more room?
My card reports it is full and I have no access to my pics
  • hardinma May 14, 2009
    Does one know what causes this? that your disk will just say it is empt
    y?
    President:
  • 919 Answers
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card and it can be used again.
Posted on May 11, 2009
Vivatar v69379ua
If you are tethering camera to computer try plugging in the card directly to the computer via a card reader.
Diane
NYC Photo Safari
Apr 28, 2014 | Cameras
My Pentax Optio w10 displays a "lock" when I try to access the menu. What do I do? Also - how do I delete all the pics off my memory card at one time rather than one by one?
Greetings,
Check if your camera is in green mode, then all you have to do is turn on the camera and and press and release the trash button that has the green dot on it.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Cameras
My flip camera says its empty but when I try to record it says its full??
Your memory card may think it's full if you've been deleting pics from it when it's in your PC and not in the camera.
If you've offloaded all the pics you want to from your memory card, put it back in your camera and "reformat" the card - there should be instructions how to do this in your camera manual. (If you've misplaced your manual you can likely find an online version on the website of your camera manufacturer). Hopefully this will fix your problem.
From now on, (even if you have to buy a new memory card), don't do any editing or deleting of pics directly on the memory media while it is in your PC (or Mac). Offload your pics to a file of their own on the PC (you can edit pics from that file). Then put the memory card back into the camera, verify that you did indeed successfully offload the pics to the PC (with the media card out of the PC), then delete the pics from the card while it's in the camera.
Reformat the memory card periodically (in the camera) after you've offloaded your pics (reformatting will erase all pics so you've gotta be sure you captured them elsewhere) to maintain the 'health' & full functionality of your memory card.
thanks.
Apr 15, 2011 | Pure Digital Flip Video Ultra Camcorder
Kodak v1003 when i turn it on it displays internal memory full
These Kodaks need some free internal memory to work at all. You need to delete pics from the internal memory to give it elbow room before it will be able to use the external memory (i.e., a memory card).
Dec 29, 2010 | Cameras
Says internal memory is full. how do I clear it
You have to delete the pictures in the memory using the camera's function to do this. If you have a memory card in the camera, you might not be able to see the pics in the internal memory, so take it out first, then review the pics in the camera and delete as many as you can (not the ones you want to keep, obviously). When you put the memory card back in, the camera should save pics to that instead of internal memory, but if the internal memory is completely full, it can't work properly. It needs some elbow room.
Nov 28, 2010 | Kodak EasyShare Z1275 Digital Camera
When the photo camera says internal memory full - How can that be removed or what do you do about it.
Well in the software that came with the unit there is an option to download those pics to a PC or you can remove the SD card to make sure you are not deleting the wrong pics. Then access the pics showing and delete them or download
Thanks for using FIXYA
Apr 13, 2010 | Kodak EasyShare C613 Digital Camera
Internal memory is full,I have erased all
Take out memory card from camera, format internal memory to delete all pictures at once or delete them one by one.
Once memory card is inserted in camera, internal memory is no longer available to store/ delete pictures so remove memory card from camera to get access to internal memory.
Nov 06, 2009 | Kodak EasyShare C743 Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
FinePix s5700 - Memory Full Error
Ok i had the same problem. But what i did is,i removed the memory card used my memory card reader and format the memory card. The i turned the camera on and used the internal memory to take a photo.The i opened the memory slot and reinsert the the memory card and walla the memory full error was gone.
Nov 05, 2008 | Fuji FinePix S5700 Digital Camera
MEMORY FULL ?? CD310CE
if your cam is using a sd card, the card could be locked, theres a little switch on the side of the card try using that and see wat happens. its tiny on one of the sides.
Jul 01, 2008 | Cameras
Olympus FE-230 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
